[REQUEST] Borrower of a media borrows all films in the media
enriquevagu
Post by enriquevagu »
Firstly, thank you for this great software, it's huge.
I have seen that you have planned to update fields, including some of the related to where you store films (serial number, code, or whatever). I would like to ask a very simple function, if possible: when a film is borrowed by a friend, all the films in the same disc (media, box, etc., ie, with the same identifier) should be set as "borrowed" by the same friend, as they are in the same disc.
I think it would be easy to program, and quite usefull (to avoid setting all film as "borrowed". I can't program in Delphi, so I can't help, but I would like to.
Thank you very much again for your great free sofware.
Enriquevagu
This is already added in version 3.5 beta 4 when using the Loans window ;)
This is not done when changing the value of the Borrower field in main window; I'll have to add too that I guess :D
enriquevagu
Thank you!
Thank you very much!
I am trying ver. 3.5b4 at the moment, your program is great! And thank you very much for your interest in the forums relating your program.
enriquevagu
