All Movie Guide script something went wrong
kalimagdora
Post by kalimagdora »
Does not bring down : :/
Title, Description - AMG SYNOPSIS:
PLS help
thx
Re: All Movie Guide script something went wrong
Movie Title, please! :??:
Lemaireus
Post by Lemaireus »
The 'All Movie Guide' script no longer fetches the following three fields of information:
1. Movie rating
2. Plot synopsis (AMG Synopsis) [Description field]
3. Movie review (AMG Review) [Comments field]
It's possible some other fields might be pulling a blank as well.
Any help would be much appreciated, please. The last script update was done by R_V, that is, Raoul.
Raoul, if you are still around in the forum, your expertise is sorely needed once again. Or anyone else who has the skills to restore this script back to health. Raoul, Antoine, Fulvio, anyone, please?
PS: The script does not fetch the aforementioned fields of information for any movie title whatsoever. So it doesn't matter which movie title you type in: the script will draw a blank in the aforementioned three fields, perhaps more.
:zzz:
Lemaireus
Post by Lemaireus »
fulvio53s03 wrote: 2021-02-21 20:18:36 Movie Title, please! :??:
:zzz:
Fulvio, all the movie titles will produce the same blank result in the following three fields:
1. Movie rating
2. Description (Plot synopsis)
3. Comments (Review)
For example: Iron Man, Arthur, Crash, The Godfather, etc.
Lemaireus
Post by Lemaireus »
:zzz:
Movie Title: The Godfather
My script's release is 0.8.5, November 2017. Is it the last One? (it comes now from AMC download).
Every movie I look for (between you titles) gives me:
"Sorry, there are too many possible matches......"
:shaking:
Try This (tested with "All the President's Men"):
Authors=Hubert Kosior, KaraGarga, Chetan Rao, Donna Huffman, R_V, Fulvio53s03
Title=All Movie Guide
Description=All Movie Guide detailed info import with picture
Site=https://www.allmovie.com
Language=EN
Version=1.0 / febbraio 2021
Requires=3.5.0
Comments=a bug corrected by Antoine Potten|completely rewritten again for the AllRovi site by Chetan Rao.|Reworked March 2009 for changes to AllMovieGuide by Donna Huffman|Rewritten for Allmovie.com by R_V (V 0.7.0 <-> 0.7.2 Feb 2014)
RequiresMovies=1
CategoryOptions=2|3|1=Only import first category|2=Import all categories and divide by "/"|3=Import all categories and divide by ","
ProducerOptions=1|0|0=Import Production Companies into Producer Field|1=Import Releaser Company into Producer Field
SynopsisOptions=1|1|1=Import into Description Field|2=Import into Comments Field|0=DO NOT import Synopsis
ReviewOptions=2|2|1=Import into Description Field|2=Import into Comments Field|0=DO NOT import Review
AwardsOptions=2|2|1=Import into Description Field|2=Import into Comments Field|0=DO NOT import Awards List
CastOptions=3|3|1=Import Cast divided by ";"|2=Import Cast as a list (AMG Default)|3=Import Cast as a list (like IMDB)|4=Import Cast as a list within paranthesis|5=Import Cast within paranthesis
FieldforCredits=1|2|0=DO NOT import Production Credits|1=Import Production Credits into Description Field|2=Import Production Credits into Comments Field
CreditsOptions=3|2|1=Import Credits as a list (like AMG)|2=Import Credits as a list (like IMDB)|3=Import Credits as a list (within paranthesis)
CharacteristicsOptions=1|1|0=DO NOT import Characteristics|1=Import into Description Field
Picture=1|1|1=Big|2=Small
MaxResults=100|5000|100=Maximum search results returned|200=|5000=|8000=
BatchMode=0|0|0=Normal working mode|1=Batch mode: if the URL field is filled, it imports from that page instead of asking for a title
[Parameters]
program AllMovie;
  StringUtils1;
  crlf = #13#10;                        // carriage return/line feed
  tab  = #9;
  PageURL: string;
  UpdateFile: TStringList;
// simple string procedures
  while Pos(Old, S) > 0 do
  Result := S;
function RemoveWhiteSpace(S : string) : string;
    Result := StringReplaceAll(S, tab, '');
    Result := StringReplaceAll(Result, crlf, '');
    Result := Trim(Result);
function GetStringFromList(Content, Delimiter: string): string;
  Data : string;
    while(true) do
      Data := TextBetween(Content, '">', '</a>');
      if (Length(Data) = 0) then
        break;
      HTMLRemoveTags(Data);
      Data := RemoveWhiteSpace(Data);
      Result := Result + Data + Delimiter + ' ';
      Content := TextAfter(Content, '</a>');
    // remove trailing delimiter
    if (Copy(Result, Length(Result), 1) = Delimiter) then
      Result := Copy(Result, 0, Length(Result) - 1);
function GetStringFromTable(Content, Delimiter, ColDelim : string): string; // for actors
  Data, cast_role   : string;
  ColLen : Integer;
  ColLen   := Length(ColDelim);
  Result   := '';
  Content := TextBetween(Content, '<div class="cast_container">', '<span>Jump to: ') + '<div class="cast_container">';
  //Content := TextAfter(Content, '<div class="cast_container">');
  while(true) do
    Data := TextBetween(Content, '<div class="cast_name artist-name">', '<div class="cast_container">');
    // make a unique delimiter between character and name
    cast_role := Fulltrim(TextBetween(Data, '<div class="cast_role">', '</div>')); // if there is no cast_role next go line 80
    Data := StringReplaceAll(Data, '<div class="cast_role">', ColDelim);
    HTMLDecode(Data);
      break;
    // make sure we don't start with the ColDelim
    if (Copy(Data, 0, ColLen) = ColDelim) then
      Data := Copy(Data, ColLen + 1, Length(Data));
    // make sure we don't end with the ColDelim
    if (Copy(Data, Length(Data) - ColLen + 1, ColLen) = ColDelim) then
      Data := Copy(Data, 1, Length(Data) - ColLen);
    if cast_role <> '' then // if there is no cast_role necessary for actors format options
    Result  := Result + Data + '## ';
function GetStringFromTable2(Content, Delimiter, ColDelim : string): string; // for crew
  Data   : string;
  ColLen : Integer;
  Result   := '';
  Content := TextBetween(Content, '<div class="crew_container">', '<span>Jump to: ') + '<div class="crew_container">';
  //Content := TextAfter(Content, '<div class="crew_container">');
  while(true) do
    Data := TextBetween(Content, '<div class="crew_name artist-name">', '<div class="crew_container">');
    Data := StringReplaceAll(Data, '<div class="crew_role">', ColDelim);
    HTMLDecode(Data);
      break;
    Result  := Result + Data + Delimiter;
function GetStringFromAwardsTable(Content, Delimiter, ColDelim : string): string;
  Data       : string;
  RowData    : string;
  ColLen     : Integer;
  AwardTitle : string;
  AwardType  : string;
  AwardRecps : string;
  AwardYear  : string;
  Presenter  : string;
  Result   := '';
  while(true) do
    Data      := TextBetween(Content, '<h3 class="award">', '</table>');
    Presenter := FullTrim( TextBetween(Content, '<h3 class="award">', '</h3>') );
    HTMLDecode(Data);
      break;
    RowData := Data;
    RowData := TextAfter(Rowdata, '<tbody>');
    while(true) do
      Data := TextBetween(RowData, '<tr>', '</tr>');
        break;
      Data := StringReplace(Data, '<td class="award-type"', '<td class="award-type"><td class="award-type"');
      Data := StringReplace(Data, '<td class="award-title"', '<td class="award-title"><td class="award-title"');
      Data := StringReplace(Data, '<td class="award-year"', '<td class="award-year"><td class="award-year"');
      AwardType  := TextBetween(Data, '<td class="award-type">', '</td>');
      AwardTitle := TextBetween(Data, '<td class="award-title">', '</td>');
      AwardRecps := TextBetween(Data, '<div class="recipients">', '</div>');
      AwardYear  := TextBetween(Data, '<td class="award-year">', '</td>');
      HTMLRemoveTags(AwardType);
      HTMLRemoveTags(AwardTitle);
      HTMLRemoveTags(AwardRecps);
      HTMLRemoveTags(AwardYear);
      AwardType := FullTrim(AwardType);
      AwardTitle := FullTrim(AwardTitle);
      AwardRecps := FullTrim(AwardRecps);
      AwardYear := FullTrim(AwardYear);
      if (Length(AwardType) > 0) then
        AwardType := ' (' + AwardType + ')';
      Data       := AwardTitle + AwardType + ColDelim + AwardRecps + ColDelim + AwardYear + ColDelim + Presenter;
      Result     := Result + Trim(Data) + Delimiter;
      RowData    := TextAfter(RowData, '</tr>');
    Content := TextAfter(Content, '</table>');
function StrOccurs(Text, SearchText: string) : integer;
   loc, len : integer;
  StrOccurs := 0;
  len       := length(SearchText);
  loc       := 1;
    loc := Pos(SearchText, Text);
    if loc > 0 then
      StrOccurs := StrOccurs + 1;
      loc  := loc + len;
      Text := Copy(Text, loc, Length(Text) - loc);
  until(loc <= 0);
// Loads and analyses search results page
procedure AnalyzeSearchResults(MovieTitle: string);
  NumResults, MaxResults, Code : Integer;
  Address, MovieResults : string;
  MaxResults := GetOption('MaxResults');
  Page.Text := GetPage('https://www.allmovie.com/search/movies/' + MovieTitle);
  NumResults := 0;
  if Pos('search results for ', Page.Text) > 0 then
    MovieResults := TextBetween(Page.Text, '<li class="filter-movies active">', '</li>');
    MovieResults := StringReplace(MovieResults, ',', '');
    MovieResults := StringReplace(MovieResults, '+', '');
    NumResults := StrToInt(TextBetween(MovieResults, '(', ')'), Code);
    if Code > 0 then
      NumResults := 0;
    if (NumResults > 0) and (NumResults <= MaxResults) then
      PickTreeAdd(IntToStr(NumResults) + ' results found for "' + MovieName + '"', '');
      AddMoviesTitles(MovieTitle);
        AnalyzePage(Address);
  if (NumResults > MaxResults) then
    ShowMessage('Sorry, there are too many possible matches, please adjust your search and retry.')
  if NumResults = 0 then
    ShowMessage('Sorry, no movies found.');
  // cleanup
// Loads and analyses a movie page
  if CanSetField(fieldURL) then SetField(FieldURL, Address);
  AnalyzeMoviePage(Address, Page);
// Extracts movie details from page
procedure AnalyzeMoviePage(Address: String; MoviePage: TStringList);
  Page: string;
  Value, Value2, Temp, Writer, Composer: string;
  Content: string;
  Delimiter : string;
  Dummy: string;
  SubPage: TStringList;
  Rating : real;
  Page    := MoviePage.Text;
  SubPage := TStringList.Create;
  // Original title
    Value := TextBetween(Page, '<h2 class="movie-title" itemprop="name">', '<');
    Value := UTF8Decode(Value);
    Value := FullTrim(Value);
    HTMLRemoveTags(Value);
    HTMLDecode(Value);
  Content := Page;
  // Year
    Value := TextBetween(Page, '<span class="release-year">(', ')');
    SetField(fieldYear, Value);
  // Length
    Value := TextBetween(Page, 'Run Time - <span>', ' min');
    SetField(fieldLength, Value);
  // Country
    Value := TextBetween(Page, 'Countries - <span>', '</span>');
  // AKA -> translated title
    Value := TextBetween(Page, '<h4>Alternate Title</h4>', '</span>');
  // Rating
//    Value := TextBetween(page, 'itemprop="ratingValue">', '</div>');
    Value := TextBetween(page, '"aggregateRating": {', '}');
    Value := TextBetween(Value, '"ratingValue": "', '"');
    Rating := StrToFloat(Value);
    SetField(fieldRating, FloatToStr(Rating));
  // Certification
  if CheckVersion(4,2,0) = True then
    Value := TextBetween(Content, 'MPAA Rating - <span>', '</span>');
    Value := AnsiUpperCase(Value);
    Value := StringReplace(Value, 'PG13', 'PG-13');
    Value := StringReplace(Value, 'NC17', 'NC-17');
    SetField(fieldCertification, Value);
  // Director
    Value := TextBetween(Content, 'Directed by ', '</span>');
    Value := GetStringFromList(Value, ',');
  // Genre -> category
    Value := TextBetween(Content, 'Genres - ', '</span');
    if GetOption('CategoryOptions') = 1 then
      Value := TextBetween(Value, '">', '</a>');
      if GetOption('CategoryOptions') = 2 then
        Delimiter := '/';
      if GetOption('CategoryOptions') = 3 then
        Delimiter := ',';
      Dummy := GetStringFromList(Value, Delimiter);
      // sub-genres
      Value := TextBetween(Content, 'Sub-Genres - ', '</span>');
      Value := GetStringFromList(Value, Delimiter);
      if Length(Value) > 0 then
        Value := Dummy + Delimiter + ' ' + Value
        Value := Dummy;
  // Producing company  -> producer
    Value := '';
    if GetOption('ProducerOptions') = 0 then
      Value := TextBetween(Page, '<h4>Produced by</h4>', '</div>');
    if GetOption('ProducerOptions') = 1 then
      Value := TextBetween(Page, '<h4>Released By</h4>', '</div>');
  // Image
  if CanSetPicture then
    Value := TextBetween(Page, ' <div class="poster">', '</div>');
    Value := TextBetween(Value, '<img src="', '"');
    Value := StringReplace(Value, '?partner=allrovi.com', '');
    Value := StringReplace(Value, 'https', 'http');
    if GetOption('Picture') = 1 then
    Delete(Value, Pos('_derived', Value), (Pos('_m0/', Value))-(Pos('_derived', Value))+4);
    // don't bother getting the default "no-image"
    if ( (Length(Value) > 0) and (Pos('no-image', Value) = 0) ) then GetPicture(Value);
  // Plot synopsis
  if CanSetField(fieldComments) or CanSetField(fieldDescription) then
    // store the author of the synopsis
//    Dummy := TextBetween(Page, '<h4 class="review-author headline" itemprop="author" itemscope itemtype="https://schema.org/Person">', '</h4>');
//    Dummy := TextBetween(Page, '<section class="review read-more synopsis">', '</section>');
//    Dummy := TextBetween(Dummy, 'by <span itemprop="name">', '</span>');
//    Value := TextBetween(Page, '<div class="text" itemprop="description">', '</div>');
    Dummy := TextBetween(Dummy, '<div class="text">', '</div>');
    HTMLRemoveTags(Dummy);
    Dummy := UTF8Decode(Dummy);
    if GetOption('SynopsisOptions') = 1 then
	  //if (GetOption('ReviewOptions') = 1) or (GetOption('AwardsOptions') = 1) or (GetOption('FieldforCredits') = 1) then
	    Value := 'AMG SYNOPSIS: ' + CRLF + fulltrim(Dummy);
    if GetOption('SynopsisOptions') = 2 then
      //if (GetOption('ReviewOptions') = 2) or (GetOption('AwardsOptions') = 2) or (GetOption('FieldforCredits') = 2) then
	    Value := 'AMG SYNOPSIS: ' + Value;
  // Characteristics
  if (CanSetField(fieldComments)) and (GetOption('CharacteristicsOptions') > 0) then
  Value := TextBetween(Page, '<h3>Characteristics</h3>', '</section>');
  Value := StringReplace(Value, '</h4>', ' : </h4>');
  Value := StringReplace(Value, '</4>', ' : </h4>'); // because sometimes the html code is broken on AMG site
  Value := StringReplace(Value, '<h4>', '<h4>##');
  HTMLRemovetags(Value);
  HTMLDecode(Value);
  Value := RemoveSpaces(Value, True);
  Value := StringReplace(Value, '##', crlf);
  SetField(fieldDescription, GetField(fieldDescription) + CRLF + CRLF + 'CHARACTERISTICS:' + Value + crlf + crlf);
  // Review -> description
  if (CanSetField(fieldComments) or CanSetField(fieldDescription)) and (GetOption('ReviewOptions') > 0) and (Pos('<li class="tab review">', Page) > 0) then
    // get the page
    SubPage.Text := GetPage(Address + '/review');
    Dummy := TextBetween(SubPage.Text, '<span itemprop="author">', '</span>');
    // get the review
    Content := TextBetween(SubPage.Text, 'itemprop="reviewBody">', '</section>');
    Content := RemoveSpaces(Content, True);
    Content := StringReplace(Content, '</p>', #13#10 + #13#10);
    HTMLRemoveTags(Content);
    HTMLDecode(Content);
    Value := UTF8Decode(Content);
    if (Length(Value) > 0) then
      Value := Fulltrim(Value) + ' -- ' + Dummy + #13#10 + #13#10;
    if GetOption('ReviewOptions') = 1 then
	  //if (GetOption('SynopsisOptions')= 1) or (GetOption('AwardsOptions')= 1) or (GetOption('FieldforCredits')= 1) then
	    Value := 'AMG REVIEW: ' + Value;
    if GetOption('ReviewOptions') = 2 then
	  //if (GetOption('SynopsisOptions')= 2) or (GetOption('AwardsOptions')= 2) or (GetOption('FieldforCredits')= 2) then
  // Awards -> description
  if (CanSetField(fieldComments) or CanSetField(fieldDescription)) and (GetOption('AwardsOptions') > 0) and (Pos('<li class="tab awards">', Page) > 0) then
    // get the page
    SubPage.Text := GetPage(Address + '/awards');
    // get the awards panel content -- this yields the awards
    Content := TextAfter(SubPage.Text, '<div class="awards-box">');
    Value := GetStringFromAwardsTable(Content, '~~ ', '||');
    Value := StringReplace(Value, '~~ ', #13#10);
    Value := StringReplace(Value, '||', ' - ');
      if GetOption('AwardsOptions') = 1 then
        SetField(fieldDescription, GetField(fieldDescription) + 'AWARDS:' +#13#10 + Value + #13#10);
      if GetOption('AwardsOptions') = 2 then
        SetField(fieldComments, GetField(fieldComments) + 'AWARDS:' + #13#10 + Value + #13#10);
  // Cast -> actors
  if CanSetField(fieldActors) or CanSetField(fieldComments) or CanSetField(fieldDescription) or (CheckVersion(4,2,0) and (CanSetField(fieldWriter) or CanSetField(fieldComposer))) then
    // get the page
    SubPage.Text := GetPage(Address + '/cast-crew');
    // get the center panel content -- this yields the Cast table
    Content := TextBetween(SubPage.Text, '<h2>Cast</h2>', '<h2>Crew</h2>');
    Value := GetStringFromTable(Content, '~~ ', '||');
      // remove double spaces if only actor name given
      while Pos('  ', Value) > 0 do
        Delete(Value, Pos('  ', Value), 2);
      if GetOption('CastOptions') = 1 then
        Value := StringReplaceAll(Value, '~~ ', ';');
        Value := StringReplace(Value, '## ', ';');
        Value := StringReplaceAll(Value, '||', '-');
        SetField(fieldActors, Value);
      if GetOption('CastOptions') = 2 then
        Value := StringReplace(Value, '## ', #13#10);
        if (Copy(Value, Length(Value) - 1, 2) = #13#10) then
          Value := Copy(Value, 0, Length(Value) - 2);
      if GetOption('CastOptions') = 3 then
        Value := StringReplace(Value, '||', ' ... ');
      if GetOption('CastOptions') = 4 then
        Value := StringReplace(Value, '~~ ', ')'+#13#10);
        Value := StringReplace(Value, '||', ' (');
      if GetOption('CastOptions') = 5 then
        Value := StringReplace(Value, '~~ ', '), ');
        Value := StringReplace(Value, '## ', ', ');
        if (Copy(Value, Length(Value) - 1, 2) = ', ') then
    // ProductionCredits -> Comments/Description
    Content := TextBetween(SubPage.Text, '<h2>Crew</h2>', '</section>');
    // transform the weirdly formatted list into a pseudo table so we can
    // reuse existing
    Value := GetStringFromTable2(Content, '~~ ', '||');
      // remove double spaces if only name given
      // begin get composer and writer
        Value2 := '%Name : '+Value;
        Value2 := StringReplace(Value2, '~~ ', ']#'+#13#10+'%Name : ');
        Value2 := deleteEnd(Value2, '%Name : ');
        Value2 := StringReplace(Value2, '||', ' [');
        if (Copy(Value2, Length(Value2) - 1, 2) = #13#10) then
        Value2 := Copy(Value2, 0, Length(Value2) - 2);
        // start loop
        While Pos('#', Value2) > 0 do
          Temp := TextBetween(Value2, '%', '#');
          if Pos('Composer', Temp) > 0 then
          Composer := Composer+TextBetween(Temp, 'Name : ', ' [')+', ';
          if (Pos('Screenwriter', Temp) > 0) OR (Pos('Screen Story', Temp) > 0) then
          Writer := Writer+TextBetween(Temp, 'Name : ', ' [')+', ';
          Delete(Value2,1,Pos('#',Value2));
        // end loop
        Composer := deleteEnd(Composer, ', ');
        SetField(fieldComposer,Composer);
        Writer := deleteEnd(Writer, ', ');
        SetField(fieldWriter,Writer);
      // end get composer and writer
      if GetOption('CreditsOptions') = 1 then
      if GetOption('CreditsOptions') = 2 then
      if GetOption('CreditsOptions') = 3 then
      if GetOption('FieldforCredits') = 1 then
        SetField(fieldDescription, GetField(fieldDescription) + 'PRODUCTION CREDITS:' + #13#10 + Value + crlf + crlf);
      if GetOption('FieldforCredits') = 2 then
        SetField(fieldComments, GetField(fieldComments) + 'PRODUCTION CREDITS:' + #13#10 + Value + crlf + crlf);
  SubPage.Free;
  // remove trailing newline from description or comments
  Value := GetField(fieldDescription);
  While Copy(Value, Length(Value) - 1, 2) = #13#10 do
  Value := GetField(fieldComments);
// Adds movie titles from search results to tree
procedure AddMoviesTitles(Title : string{; NumResults: Integer});
  PageText : string;
  SearchAddress : string;
  MovieTitle, MovieAddress, MovieYear, MovieDirector, Temp: string;
  SearchAddress := 'https://www.allmovie.com/search/movies/' + Title;
  Page.Text := GetPage(SearchAddress);
  PageText := Page.Text;
  Delete(PageText, 1, Pos('<ul class="search-results">', PageText)-1);
  // Every movie entry begins with string "<tr>"
  while Pos('<li class="movie">', PageText) > 0 do
    Temp := TextBetween(PageText, '<li class="movie">', '</li>');
    MovieAddress := 'https://www.allmovie.com/movie' + TextBetween(Temp, '<a href="https://www.allmovie.com/movie', '"');
    MovieTitle := UTF8Decode(TextBetween(Temp, MovieAddress+'">', '</a>'));
    MovieYear := TextBetween(Temp, MovieTitle+'</a>', '</div>');
    MovieYear := FullTrim(MovieYear);
    MovieDirector := UTF8Decode(TextBetween(Temp, 'Directed by: ', '</div>'));
    HTMLRemoveTags(MovieDirector);
    MovieDirector := FullTrim(MovieDirector);
    If MovieDirector <> '' then
    MovieDirector := ' by ' + MovieDirector;
    MovieTitle := MovieTitle + ' ' + MovieYear + MovieDirector;
    // add movie to list
    // remove the entry we just processed
    CutAfter(PageText, '</li>');
// Extracts single movie detail (like director, genre) from page
  Result := '';
    CutBefore(Page, StartTag);
    if Length(CutTag) > 0 then
      CutAfter(Page, CutTag);
    // remove html tags and decode html string
    HTMLRemoveTags(Result);
    HTMLDecode(Result);
    Result := RemoveWhiteSpace(Result);
//  ShowMessage('DEBUG: GetStringFromHTML - StartTag "'+StartTag+'", CutTag "'+CutTag+'", EndTag "'+EndTag+'", Result "'+Result+'" ___ '+Page);
// Delete substring of a string if end string
function deleteEnd(Value, EndValue : String) : String;
  if copy(Value,length(Value)-length(EndValue)+1,length(Value)) = EndValue then
        Value := copy(Value,1,length(Value)-length(EndValue));
  result := Value;
// Program
      if ShowWarning('Old version of file "Stringutils1.pas" detected: v'+IntToStr(StringUtils1_Version)+#13#10+'The script requires at least version 7.'+#13#10+'Download and install latest version now ?') = True then
          UpdateFile.Text := GetPage('http://update.antp.be/amc/scripts/StringUtils1.pas');
          UpdateFile.Free;
          ShowInformation('StringUtils1 has been updated. Please restart "All Movie Guide" script now. Thank you.');
          Exit;
          ShowInformation('You can download latest version of "StringUtils1.pas" using script [ UPDATE SCRIPTS ] or via http://update.antp.be/amc/scripts');
          Exit;
  // Check AMC version
  if CheckVersion(4,2,1) then
    MovieName := GetField(fieldUrl);
    if (GetOption('BatchMode') = 1) and (Pos('allmovie.com', MovieName) > 0) then
      if Pos('https', MovieName) > 0 then
      AnalyzePage(MovieName)
      AnalyzePage(StringReplace(MovieName, 'http', 'https'));
      if MovieName = '' then MovieName := GetField(fieldTranslatedTitle);
      if Input('All Movie Import', 'Enter title (only letters, digits and spaces) or URL:', MovieName) then
        if Pos('allmovie.com', MovieName) > 0 then
        AnalyzeSearchResults( StringReplace(URLEncode(MovieName), '%20', '+') );
  if ShowWarning('This script requires a newer version of Ant Movie Catalog'+#13#10+'at least the 4.2.1 BETA version available here : '+#13#10+'http://forum.antp.be/phpbb2/viewtopic.php?t=4844'+#13#10#13#10+'Click on ''Ok'' to launch directly the adress in your browser') = True then
  Launch('http://forum.antp.be/phpbb2/viewtopic.php?t=4844', '');
Lemaireus
Post by Lemaireus »
Fulvio, thank you for the work you have put in. :grinking:
To do away with the problem of too many results, you can go to 'Script Options>MaxResults' and change the number therein.
Your script works, but there are three problems:
1. It does not accurately import the movie rating from 'All Movie Guide' website. (The script should pick 'AllMovie Rating' not 'User Ratings'.)
2. It imports the plot synopsis in the 'description' field, but there is a text formatting issue with the paragraphs not coming out right. It does not import the name of the synopsis writer.
3. The script does not import the review.
Thank you for some wonderful work which gives hope that the script will soon be restored back to pristine health soon. :clapping:
Lemaireus
Post by Lemaireus »
Please use the title "The Kid" (1921) to test the description (AMG Synopsis) field because the text block is long enough to show formatting issues.
Please use the title "The Great Buck Howard" (2008) to test the comments (AMG Review) field because it is a two paragraph review and will thus show text formatting issues, if there are any.
kalimagdora
fulvio53s03 :clapping:
Thank you so much for helping us.
The new script works, but for me the original title field is still blank, and AMG REVIEW I can't find it either. What have I done wrong?
thx
Updated testing "The Great Buck Howard"
deleted as incorrect
:innocent:
Lemaireus
Post by Lemaireus »
Thank you once again, Fulvio, for all the work you have put in. However, the script still seems a little buggy, with the following two problems:
1. The plot synopsis does not get picked up.
2. The review does not get picked up.
Improvements over the last version you posted earlier:
1. The AMG movie rating is now being picked up correctly.
2. The plot synopsis (description) text box picks up the name of the synopsis writer.
I'll shortly post two screenshots: first, of the information imported by the old AMG script, and second, of the information imported by your version of the script.
Lemaireus
Post by Lemaireus »
Screenshot of the information for the title "The Great Buck Howard" imported by the earlier version of the script, when it was fully functional:
https://ibb.co/QNm7DXj
Screenshot of the information for the title "The Great Buck Howard" imported by the new version of the script:
https://ibb.co/5GgXvTn
Lemaireus
Post by Lemaireus »
This is how the imported information from All Movie Guide should look (Raoul's script [R_V], v. 0.7.4?):
This is how the imported information from All Movie Guide currently looks (Fulvio's script, v. 1.1):
PS: I have posted the screenshots solely to highlight the missing elements in the "Description" and "Comments" fields. The new script by Fulvio works well in all other respects, including importing the picture.
Once again, thank you, Fulvio, and looking forward to a perfect script sometime soon. Cheers!
Sorry for my mistake, giving you an incorrect pre-release... :ha:
I hope the following release could be satisfactory:
obsolete code deleted
Lemaireus
Post by Lemaireus »
fulvio53s03 wrote: 2021-02-27 10:46:08 I hope the following release could be satisfactory
Thank you very much, Fulvio, the new version you have posted is nearly perfect. One little detail, about a formatting issue: the comments section picks the AMG reviews as one text block, even when the website has split the text in two paragraphs.
For example, "Comments" section of "The The Great Buck Howard" should show as:
But in the new AMG script it shows up as one text block:
The same text formatting issue is there in the "Description" (AMG Synopsis) section as well (tested with "The Kid" 1921). These are the only two minor bugs left in an otherwise perfect script.
Many, many thanks for helping out.
Lemaireus
Post by Lemaireus »
PS: The new script is not picking up the "AllMovie Rating". Tested with the following titles:
The Kid
Zulu
The Wind Will Carry Us
Lemaireus wrote: 2021-02-27 15:20:22 .......
please send me a screenshot about "Description" in "The Kid" as i cannot see what you are saying.
The page on web is the following?
https://www.allmovie.com/movie/the-kid-v27169
Have a good day.
Lemaireus
Post by Lemaireus »
Here are the screenshots:
1. This is how the text block appears in the "Description" field with the new script, with the three extra line/paragraph breaks highlighted with a red arrow:
2. This is how the text block should appear in the "Description" (AMG Synopsis) field, without any line or paragraph breaks:
3. This is how the text block appears on the link you have provided: https://www.allmovie.com/movie/the-kid-v27169, without any line or paragraph breaks:
Once again, Fulvio, thank you very much, and wish you a wonderful day too!
