suggestion
sdf
suggestion
Post by sdf »
i have a problem with the "auto-handle prefixes" option. it works like a charm to sort the movies in the left movie list box, but when printing / renumbering etc, it doesn't (i.e. the movies get sorted according to the full original name, so that all movies beginning with "the" will be sorted "wrong" imo)...
is there a way or a plan to change this behaviour? thanks!
sdf
Post by sdf »
i forgot:
how about an option to run the pictures through netpmb when exporting to html to get smaller picture sizes...
In version 3.5 it will be possible to sort using Formatted Title, and so the prefixes and translated titles will be handled correctly ;)
About picture reduction, you could use a program like Irfan View to reduce them after the export, but currently there is nothing automatic. I'll see if I add that in a future version.
