I can't seem to find it, and unsure if its possible.
But when i sort on imdb rating, it opens the movielist, and shows for every value the movies that match that rating.
But I cant find a way to minimize them so i only see the rating, and not evry movie that matches that value.
for instance
- 9.1 (1)
Lord of the Rings 3
-9.0 (2)
Film number 788
Film number 356
-8.9 (7)
Film number 3
Film number 88
Film number 247
Film number 384
Film number 900
Film number 907
Film number 1064
But the bigger the database, the longer that list gets. So now i have to press every - <hich is very timeconsuming on big databases.
Minimizing list
You are using version 3.4.3 or version 3.5 beta ?
The version 3.4.3 does not expand all groups by default if I remember well.
In version 3.5 in the Preferences, on the Movie List page, there is an option to specify if you want to have all groups expanded by default or not.
If you want something to easily expand/collapse all groups, I could add a Ctrl+ and Ctrl- shortcut to expand/collapse all.
joly
