default value in procedure
scorpion7552
Post by scorpion7552 »
In Delphi, there is a possibility to declare procedures or functions with default parameters
If I am right, the syntax is something like this
procedure myproc(var1: string; var2 : string = 'default value');
but, this does not work inside scripts. What do you think of that :/
In the same idea, could it be possible to have the list of Delphi functions and procedures available in scripts (only the list, for the parameters we can search elsewhere :)) . That would be great ;)
If it does not work in the scripts it means that IFPS does not support it, I guess :D
For a list of available procedures and functions (except those that I added and that are listed) I should go in IFPS source code and make a list, since I do not know myself all the available procedure and functions.
