Automatic adding names from files....
This is a pure detail: i think it's useful to add new records from a file directly adding name from the file; so i put "add name from files" in preferences.
But sometimes i have to read files hoping not to change that info (example: a 2CDs movie...).
I know what u'll think: "go to prefs and put automatition OFF"...
Isn't it possible to decide after the file reading if i want to add name too?
Isn't it possible to create a 2nd choice in preferences "ADD FROM FILE NAME IF TITLE FIELD IS BLANK ONLY"?
ah... who can i change this reading from OriginalTitle to TranslatedTitle (i'm not american, so often my files are with Translated Title)?
Thx
ABN
In the future I may improve the file import thing, but for the moment and for version 3.5 this will stay as it is currently ;)
ABNormal
Post by ABNormal »
thank you.
so if u'll work (one of these days/months..) on import from file options, whay not to add a text converter.... from "The.Core" and from "The_Core" to "The Core"?
It should be useful 4 some of us....
bye
ABN
Yes, I will add that too someday
