Autoupdate Movie Details
Lucrian
Post by Lucrian »
It is possible to put a button which will open a dialog box where the user can choice a range (e.g. from 47 to 59), and the program will automaticaly update those movies. The update will made from the URL. Obviosly, this option will be not available for movies which haven't the URL field complete.
Lucrian
Post by Lucrian »
That was a question. Sorry for "?" sign.
This could be done by selecting those movies in the main list before calling the script (with Tools -> Scripting)
For using the URL field rathing than manual inputing the title, the script should be a little modified, but this depends of the script that you use.
Lucrian
Post by Lucrian »
I use version 3.4.3 from 22.12.2004 (latest version stable).
10X 4 answer
sleipner
Post by sleipner »
i edited imdb script bit to do that while ago.. this is for 3.5 beta tho..
its at end of imdb.ifs file so just replace it with this..
how it works(or should work :P ):
if url contains 'imdb.com' script updates all data directly from that url
else it works like unedited script.
// ***** beginning of the program *****
  if CheckVersion(3,5,0) then
      //for imdb url
  MovieName := GetField(fieldURL);
  if Pos('imdb.com', MovieName) > 0 then
  begin  //get with imdb url
     AnalyzeMoviePage(GetPage(MovieName));
  end else  //end get with imdb url
  begin //normal search
      if not Input('IMDB Import', 'Enter the title or the IMDB URL of the movie:', MovieName) then
        Exit;
    if MovieName <> '' then
        AnalyzeResultsPage(MovieName)
        if (GetOption('BatchMode') = 1) or (GetOption('PopularSearches') = 1) then
          AnalyzeResultsPage('http://us.imdb.com/find?tt=1;q=' + UrlEncode(MovieName))
          AnalyzeResultsPage('http://us.imdb.com/find?more=tt;q=' + UrlEncode(MovieName));
  end //end normal search
sleipner
Post by sleipner »
ok i made quick view to if 3.4 version script..
it should work in that too just by fixing few lines..
to
if CheckVersion(3,4,3) then
and
to
ShowMessage('This script requires a newer version of Ant Movie Catalog (at least the version 3.4.3)');
onli first edit is needed to get it work with old version.. second one isnt really needed..
hope it helps :)
