[ITA] Is Anyone Able to create a script for www.film.tv.it?
ABNormal
Post by ABNormal »
I'm going crazy, but i'm not able to understand how these scripts work.
So i'm not able to create a script for www.film.tv.it, maybe the most exaustive movie site in italian.
So is anyone able to help me plz?
Thank You.
ABN
ABNormal
Post by ABNormal »
time passed and no one helped me.
www.film.tv.it is simply one of the most complete databases (with pics too) written in italian.
italians can find almost everything.
plz do this work
i'm unable to understand how these scripts work
ABN
P2
Simple script
Post by P2 »
Below are simple script i made for www.film.tv.it
Use this script as base for your development.
Regards
Pivello
// GETINFO SCRIPTING
// Film.TV.it - by Pivello
*  Film.TV.it, http://www.Film.TV.it              *
* (P)2005 Pivello                                 *
*  30.01.2005 First beta test release             *
*  31.01.2005 First pubblic release               *
*  02.02.2005 Add Dinolib routine for big picture *
*  For use with Ant Movie Catalog 3.4.1 ->        *
*  www.antp.be/software/moviecatalog              *
program FilmTVIt;
  LargePicture = True; // CHANGE TO FALSE IF WANTED SMALL PICTURE
  UrlBase = 'http://www.film.tv.it';
  QueryBase = UrlBase + '/cerca.php?ricerca=avanzata&titolo=';
  QueryFilm = UrlBase + '/scheda.php?film=';
  ImagePath = UrlBase + '/imgbank/';
  cStartId = 'Verde"><a href="scheda.php?film='; // ID start marker
  cEndId = '" class="fTitolettoFilm"';           // ID end marker
  cStartTitle = '/> ';                      // Title start marker
  cEndTitle = '</a></span>';                     // Title end marker
  cStartTranslTitle = 'fTitoloFilmBianco">';     // Translated title start marker
  cEndTranslTitle = '</span>';                   // Translated title end marker
  cStartImg = 'img src="imgbank/';               // Image start marker
  cEndImg = '" width="';                         // Image end marker
  cStartGeneric = 'Lite" bgcolor="#5B6E80" valign="top">';
  cEndGeneric = ' ';                        // Generic field marker
  cStartDirector = 'fLinkBianco>';               // Director start marker
  cEndDirector = '</a>';                         // Director end marker
  cStartCast = 'fLinkBianco>';                   // Actor start marker
  cEndCast = '</a>';                             // Actor end marker
  cBeginDesc = '"La Trama" /></p>';              // Description begin marker
  cStartDesc = '<p class="testo">';              // Description start marker
  cStartComm = '<p class="testo"><i>';           // Comment start marker
  cEndComm = '</i></p>';                         // Comment end marker
  MovieUrl, MovieName, OriginalStr, TranslatedStr, PageStr:  string;
// PAGE PACKING (remove extra spaces, tabs & CR)
// IN:  page Url     (string)
// OUT: compact page (string)
  Temp: string;
  PackedPage: string;
  CharPos: Integer;
  n: Integer;
  Page.Text := GetPage(Url);
  for n:=0 to Page.Count-1 do
   if CharPos = 0 then
   if CharPos <> 0 then
     Temp := copy(PackedPage, 1, CharPos -1);
  result := PackedPage;
// GET FIELD VALUES FROM PACKED PAGE
// IN:  Start marker     (String)
//      End marker       (string)
//      Cut Start Marker (bool)
//      Cut End Marker   (bool)
// OUT: value            (string)
function GetValue(StartMarker, EndMarker: string; CutStartMarker, CutEndMarker: boolean): string;
  StartPos: integer;
  EndPos: integer;
  Value: string;
  Value := '';
  StartPos := pos(StartMarker, PageStr);
  if (StartPos > 0) then
   Delete(PageStr, 1, StartPos-1);
  EndPos := pos(EndMarker, PageStr);
  if ((StartPos > 0)and(EndPos > 0)) then
    if CutStartMarker then
     StartPos := StartPos + length(StartMarker);
    if not CutEndMarker then
     EndPos := EndPos + length(EndMarker);
    Value := copy(PageStr, StartPos, EndPos-Startpos);
    Delete(PageStr, 1, EndPos);
  result := Value;
// ReadPicture - by Dinolib
// IN:
// OUT:
procedure ReadPicture;
  ImageLink: string;
Begin
  ImageLink := ImagePath + getValue(cStartImg, cEndImg, true, true);
  if Pos('DUMMY/locandina.gif',ImageLink)>0 then
  if LargePicture then
    ImageLink := StringReplace(ImageLink,'/LOC/','/GALLERY/');
  GetPicture(ImageLink, false);
// ANALYZE MOVIE DATA PAGE
// IN:  none
// OUT: set Ant fields
procedure AnalyzeMoviePage;
  Cast, TempStr: string;
  // Get packed title main page
  // Translated Title field
  SetField(fieldTranslatedTitle, getValue(cStartTranslTitle, cEndTranslTitle, true, true));
  // Get film image
  ReadPicture;
  // Original Title field
  SetField(fieldOriginalTitle, getValue(cStartGeneric, cEndGeneric, true, true));
  if(GetField(fieldOriginalTitle)='')then
  // Country field
  SetField(fieldCountry, getValue(cStartGeneric, cEndGeneric, true, true));
  // YearField
  SetField(fieldYear, getValue(cStartGeneric, cEndGeneric, true, true));
  // Director Field
  SetField(fieldDirector, getValue(cStartDirector, cEndDirector, true, true));
  // Actors Field
  Cast := '';
   TempStr := getValue(cStartCast, cEndCast, true, true);
   if ((Cast<>'') and (TempStr<>'')) then
    Cast := Cast + ', ';
   Cast := Cast + TempStr;
  until((TempStr='')or(Length(TempStr)>40));
  SetField(fieldActors, Cast);
  // Category Field
  SetField(fieldCategory, getValue(cStartGeneric, cEndGeneric2, true, true));
  // Duration field
  TempStr := getValue(cStartGeneric, cEndGeneric2, true, true);
  SetField(fieldLength, Copy(TempStr,1,Length(TempStr)-1));
  // Producer Field
  //SetField(fieldProducer, getValue( , , true, true));
  // Description Field
  Delete(PageStr, 1, Pos(cBeginDesc, PageStr) + Length(cBeginDesc));
  SetField(fieldDescription, getValue(cStartDesc, cEndDesc, true, true));
  // Comments Field
  SetField(fieldComments, getValue(cStartComm, cEndComm, true, true));
  // Movie URL field
  SetField(fieldURL, MovieUrl);
  // Display search result
  DisplayResults;
// IN:  OneFilm flag (bool)
// OUT: one page ID  (string)
  TempIdFilm: string;
  TempTitle: string;
  StartPos: integer;
  EndPos: integer;
  if OneFilm then
    StartPos := pos(cStartId, PageStr);
    EndPos := pos(cEndId, PageStr);
    StartPos := StartPos + Length(cStartId);
    TempIdFilm := copy(PageStr, StartPos, EndPos-Startpos); // Get ID
    result := QueryFilm + TempIdFilm;
     if StartPos > 0 then
       StartPos := pos(cStartTitle, PageStr);
       EndPos := pos(cEndTitle, PageStr);
       StartPos := StartPos + Length(cStartTitle);
       TempTitle := copy(PageStr, StartPos, EndPos-Startpos); // Get Title
       PickTreeAdd(TempTitle, QueryFilm + TempIdFilm);
    until(StartPos = 0);
    result := '';
// OUT: none
procedure AnalyzeSearchPage(Url: string);
  FilmId: string;
  PageStr := RemoveExtraChars(Url);
  if pos('Non ho trovato nessun film', PageStr) > 0 then
  else if pos('Si è verificato un errore',PageStr) > 0 then
    ShowMessage('Server not available, try later / Server non disponibile, prova più tardi')
    if pos('Ho trovato 1 film', PageStr) <> 0 then
     MovieUrl := PopulatePickTree(true)  // One title found
      PopulatePickTree(false);           // More titles found..
    AnalyzeMoviePage;
// MAIN:
// IN:  none
// OUT: none
  if CheckVersion(3,4,1) then
    if (TranslatedStr <> '') then MovieName := TranslatedStr else MovieName := OriginalStr;
    if (Input('Film.TV.It - By Pivello', 'Enter the title of the movie / Inserire titolo del film:', MovieName)) then
      MovieUrl := QueryBase + UrlEncode(MovieName);
      AnalyzeSearchPage(MovieUrl);
   ShowMessage('This script requires a newer version of Ant Movie Catalog (at least the version 3.4.1)');
ABNormal
Post by ABNormal »
SMACK!!!!! :D
:grinking: :clapping: :grinking: :clapping: :grinking:
ABN
ABNormal
Post by ABNormal »
un solo dettaglio da aggiungere/correggere (ad essere perfezionisti):
nel link PHOTOGALLERY in genere c'è l'immagine segnata come LOCANDINA che è il poster grande.E' possibile aggiungere questa ricerca aggiuntiva/sostitutiva x il poster?
ANCORA GRAZIE!
Translation:
One only detail for the perfection: Inside PHOTOGALLERY linkable page normally appears, under the title "LOCANDINA", the big poster.
Is it possible to add/correct this detail, plz?
THANK YOU A LOTTTTT!
ABN
dinolib
[REL]Try this...
Post by dinolib »
this is my first attempt writing a script for Ant Movie Catalog. *test in progress!!*
I've wrote It for Version 3.5.0 RC1. But I think Pivello could translate it for 3.4.x version (just change version control,erase the GetOption call and re-insert DisplayResult call)...
I'm sorry, comments are in italian.
Few words about algorithm: look for the token 'LOCANDINA' in first page of gallery and count position in table. Then search for the image link in the same position of the word LOCANDINA...
Bug known: if the picture isn't in the first page of the gallery, it's not retrieved. :-(
Bye
[Edit]ok, I've update [Infos] section and added to script source.[/Edit]
[Edit2]semplified on ABNormal directions... [/Edit2]
Authors=Pivello
Title=FilmTV
Site=www.Film.TV.it
Language=IT
Version=02.02.2005
Requires=3.5.0
Comments=Modified by: 02.02.2005 dinolib;
License=The source code of the script can be used in another program only if full credits to script author and a link to Ant Movie Catalog website are given in the About box or in the documentation of the program
LargePicture=1|1|0=Get a small picture|1=Try to get the big picture
program FilmTVIt;
  Temp: string;
  PackedPage: string;
  CharPos: Integer;
  n: Integer;
   if CharPos = 0 then
  StartPos: integer;
  EndPos: integer;
  Value: string;
  Value := '';
  result := Value;
  ImageLink: string;
Begin
  if GetOption('LargePicture')=1 then
  GetPicture(ImageLink);
// IN:  none
  i, h, m: integer;
  Duration, Description, Cast, TempStr, TempImg, hh, mm: string;
  // Get film image
  //GetPicture(ImagePath + getValue(cStartImg, cEndImg, true, true));
  ReadPicture;
  // Country field
  // YearField
  // Director Field
  // Actors Field
  Cast := '';
  // Category Field
  // Duration field
  // Producer Field
  // Comments Field
  // Movie URL field
  TempIdFilm: string;
  TempTitle: string;
  StartPos: integer;
  EndPos: integer;
  if OneFilm then
    result := '';
// OUT: none
  FilmId: string;
    AnalyzeMoviePage;
// MAIN:
// IN:  none
// OUT: none
  if CheckVersion(3,5,0) then
You should open the script with notepad or another text editor to copy it, because if you only copy the code from AMC's editor then the info/options block is missing ;)
ABNormal
Post by ABNormal »
well
just a little step more folks....
for the large poster you should change picture link:
if in main page the little cover (the one you put in your script) in called:
http://www.film.tv.it/imgbank/LOC/MA/02939703.jpg
(master & commander little cover)
the large picture is simply:
http://www.film.tv.it/imgbank/GALLERY/MA/02939703.jpg
(master & commander LARGE poster)
so you should only find the way to modify LOC with GALLERY subfolder.
Perfection should be:
1) find LARGE POSTER (imagepath + /GALLERY/ + rest of link)
2) if found exit
3) else
4) find LITTLE POSTER in main page (imagepath + /LOC/ + rest of link)
5) if little poster is http://www.film.tv.it/imgbank/DUMMY/locandina.gif ( NOT PRESENT POSTER picture) do not add picture.
too difficult? i think not
thx a lot guys
ABN
dinolib
Post by dinolib »
OK, good news... I'll try to change the script.
Antp, can you suggest how to verify the existance of an image? It could be very usefull...
thanks in advance!
dinolib
Post by dinolib »
@ABNormal:
I've edited the script and used the URL you signaled.
I'm sorry, I don't know how to check for large image existance...
Let me know if it works well! I can try to change something if you need it.
bye
ABNormal
Post by ABNormal »
dinolib wrote:@ABNormal:
bye
no dino... pic is still the little one on main page.
i've read the html text and large picture isn't called LOCANDINA, but put into a <TR> <TD> always under the word "Locandina"... so i think it will be difficult.
watching the Extreme Movie Manager i've discovered the easiest way to reach LargePoster (film.tv uses 2 parallel folders: LOC with the little pic u see in main page, and GALLERY, where there is the Large Poster with the same name of that one before)
so instead of analyzing each pic into PhotoGallery page, it will be easier the use the second solution i wrote before.
Ciao
ABN
dinolib
Post by dinolib »
I've edited the script for the second time. Now it shold works. I've done a lot of tests.
(Nella prima versione cercavo una immagine nella gallery. Ora, secondo quanto mi hai indicato, prendo il nome immagine dalla scheda, e poi vado nella cartella GALLERY.
Purtroppo c'è il logo FILM TV impresso sull'imagine(ma questo è inevitabile) :(
I hope you'll found it usefull.
ciao
Dino
dinolib wrote: Antp, can you suggest how to verify the existance of an image? It could be very usefull...
Unfortunately it is not possible currently to check through script if a URL is valid or not, and except the GetPicture procedure there is nothing available to manage the pictures of the catalog.
ABNormal
Post by ABNormal »
dinolib wrote:I've edited the script for the second time. Now it shold works. I've done a lot of tests.
ciao
Dino
E' PERFETTO!
GRAZIE MILLE
(è vero, film.tv aggiunge il logo e la scritta sulla base e non c'è nulla da fare. ma ha tutti i titoli desiderabili. per le novità resta sempre meglio prendere la locandina da filmup -grande e "immacolata"-)
--------------translation:
It's perfect! thx a lotttt
(it's true, film.tv add a logo on their posters, but this site is the only one where italians can find about everything with posters. for newest movies maybe filmup is better: their posters are bigger and without logos)
i'll study your script
i have to learn how to create others
ANTOINE add this script into your next release. It's a masterwork :)
and plz, plz, plz create a tutorial on How-To-Create-Scripts....
a script with comments explaining what each operation does and works...
(Example: // now script look for text between '.com/' and '</size')... and so on.
ancora grazie dino
ABN
P2
Post by P2 »
Ok.
I have added the Dinolib routine in my script for AMC 3.4.x
Regards
Pivello
P.S.
If needed small pictures, just change the 'LargePicture' constant to false.
dinolib
Other Italian Scripts
Post by dinolib »
I'm going to convert all the other Italian scipts to v.3.5.0.
I'm also testing them to update where they don't work anymore (AFDigitale.it for example).
May be this night (GMT+1) I'll send to Antoine a zip file.
If you want to suggest me something, let me know!
Bye
Dinolib
Great ! Thanks for your work :)
ABNormal
Post by ABNormal »
well i tried to add a function (Rating) to dino's script.
film.tv.it uses 4 ratings:
mediocre (not so good)
sufficiente (so so)
buono (good)
ottimo (excellent).
i've "translated" these ratings into 3, 5, 7, 9 into Rating field.
It seems it works
so here is the script:
Authors=Pivello
Title=FilmTV
Site=www.Film.TV.it
Language=IT
Version=02.02.2005
Requires=3.5.0
Comments=Modified by: 02.02.2005 dinolib; 03feb2004 ABN
program FilmTVIt;
  cStartVal = 'class="fTestoBiancoLite">';
  cEndVal = '</td>';
  Temp: string;
  PackedPage: string;
  CharPos: Integer;
  n: Integer;
   if CharPos = 0 then
  StartPos: integer;
  EndPos: integer;
  Value: string;
  Value := '';
  result := Value;
  ImageLink: string;
Begin
// IN:  none
  i, h, m: integer;
  Valutaz, Val2, Duration, Description, Cast, TempStr, TempImg, hh, mm: string;
  // Get film image
  ReadPicture;
  // Country field
  // YearField
  // Director Field
   SetField(fieldRating, Val2);
  // Actors Field
  Cast := '';
  // Category Field
  // Duration field
 //Rating - Added by ABNormal
  Valutaz := (getValue(cStartVal, cEndVal, true, true));
  if (Valutaz='mediocre') then
  Val2 := '3';
  if (Valutaz='sufficiente') then
  Val2 := '5';
  if (Valutaz='buono') then
  Val2 := '7';
  if (Valutaz='ottimo') then
  Val2 := '9';
  if (Valutaz='') then
  Valutaz := '0';
  // Producer Field
  // Comments Field
  // Movie URL field
  TempIdFilm: string;
  TempTitle: string;
  StartPos: integer;
  EndPos: integer;
  if OneFilm then
    result := '';
// OUT: none
  FilmId: string;
    AnalyzeMoviePage;
// MAIN:
// IN:  none
// OUT: none
bye
ABN
dinolib
Post by dinolib »
ABN, be carefull!
Your script has a little mistake...
PageStr is managed progressively. Every time you call GetVal, pageStr is cut! So, if you place the Rating step before Actors and Category, you lost them!
Here the change you have to apply: move your code after the fieldLength step.
In this way you get all the infos! (infact length was already computed, but you break it :( )
ciao!
Dino
ABNormal
Post by ABNormal »
dinolib wrote:ABN, be carefull!
ciao!
Dino
Well, as i wrote elsewhere, i don't know anything about pascal and about these scripts, so i didn't know that they delete html after each GetVal.
So i hope that now, after this correction, there aren't other mistakes.
I'm sorry i "destroyed" your previous script, so i'm happy if my added part now will work without creating probs to your great script.
ciao
ABN
