Hi
I really liked AMC, it is the best catalogue prgram I´ve found. I am from Brazil and I saw that there is no script to any Brazilian page (often the translated title in Brazil is different from Portugal). I seached in the Internet and the best Brazilian page to get informations I´ve found seemed to be http://dvdworld.com.br. I tryed to do a script but the fact is that I don´t know Pascal at all, and of course I lost my patience.
I did a Frankenstain with the PTGATE script, it can get some informations but there is a lot of errors, someone who knows the language will take some minutes to fix it.
Thanks, and sorry, I also don´t know English.
// GETINFO SCRIPTING
// http://cinema.ptgate.pt/
// Script feito pelo O Guardião versão 1.0 Alpha 3
// 20-09-2004
* For use with Ant Movie Catalog 3.4.0 *
* www.antp.be/software/moviecatalog *
* The source code of the script can be used in *
* another program only if full credits to *
* script author and a link to Ant Movie Catalog *
* website are given in the About box or in *
* the documentation of the program *
* Please dont remove credits *
* Reportem os erros para bruno_mga@hotmail.com *
program PTGate;
BaseAddress = 'http://dvdworld.com.br/dvdworld.hts';
ManualPictureSelect = True;
ExternalPictures = False;
DescriptionToImport = 2;
MovieURL: string;
function HTMLRemove(Value: String): String;
HTMLDecode(Value);
HTMLRemoveTags(Value);
Value := Trim(Value);
result := Value;
function UpFirstLetterWord(texto:string):string; //Function Made By O Guardião
var espaco:integer;
sst:string;
texto:=AnsiUpFirstLetter(AnsiLowerCase(texto));
espaco:=Pos(' ',texto);
sst:=AnsiUpperCase(Copy(texto,espaco+1,1));
texto:=Copy(texto,1,espaco-1)+'/|\'+sst+Copy(texto,espaco+2,length(texto));
until Pos(' ',texto)=0;
texto := StringReplace(texto, '/|\', ' ');
if Copy(texto,1,1)=' ' then//se a 1º pos é espaço
texto:=Copy(texto,2,length(texto));
result:=texto;
procedure AnalyzeFilmPage(Address: String);
Page : TStringList;
Line, Value : string;
LineNr, BeginPos, EndPos: Integer;
AllTitles: TStringList;
url_imdb:string;
nome_orig:string;
nome_trad:string;
ano:string;
pais:string;
genero:string;
realizac:string;
Interpretes:string;
descricao:string;
capa:string;
value := 'http://216.247.85.101/images/'+Address+'.jpg';
// (it is working well)
GetPicture(Value, False);
Address:='http://dvdworld.com.br/dvdworld.hts?+'+Address+'+acha';
//obter nome original do filme (it often also get the year and the country, but I didn´t figure how to trim it)
LineNr := FindLine('Título Original:', Page, 0);
if LineNr<>-1 then
Value := Page.GetString(LineNr);
BeginPos := pos('/b>',value);
EndPos := pos('</f',value);
nome_orig:=copy(value,BeginPos+3,EndPos);
nome_orig:=HTMLRemove(nome_orig);
//ano (not working at all)
ano:=copy(nome_orig,length(nome_orig)-5,4);
SetField(fieldYear, ano);
SetField(fieldOriginalTitle, nome_orig);
//obter nome traduzido (it has to cut some info of the DVD)
LineNr := FindLine('<td align="left" valign="top"><font face="Arial, Helvetica, sans-serif" size="4" color="#000066"><b>', Page, 0);
nome_trad:=HTMLRemove(Value);
nome_trad:=UpFirstLetterWord(nome_trad);
SetField(fieldTranslatedTitle, nome_trad);
//realização (it seems ok)
LineNr := FindLine('Diretor:</b>', Page, 0);
if LineNr<>-1 then
realizac:=copy(value,BeginPos+3,EndPos);
realizac:=HTMLRemove(realizac);
SetField(fieldDirector, realizac);
//Intérpretes (it seems ok)
LineNr := FindLine('Atores: </b>', Page, 0);
if LineNr<>-1 then
Interpretes:=copy(value,BeginPos+3,EndPos);
Interpretes:=HTMLRemove(Interpretes);
SetField(fieldActors, Interpretes);
//descrição (it seems ok)
LineNr := FindLine('<b>Sinopse:</b>', Page, 0);
if LineNr<>-1 then
descricao:=copy(value,BeginPos+3,EndPos);
descricao:=HTMLRemove(descricao);
SetField(fieldDescription, descricao);
result := -1;
if StartAt < 0 then
StartAt := 0;
result := i;
LineNr, StartPos, EndPos: Integer;
x:integer;
MovieAddress, findMovieName,linedown : string;
guardar,url, nome_filme:string;
if (pos('títulos que contém a palavra chave', Page.Text)>0) then //search portuguese
// need a report when the seach doesn´t have ant result
LineNr :=0;
LineNr := FindLine('+acha', Page, LineNr);
If LineNr >0 Then Begin
StartPos := pos('hts?+', Line)+1;
url:=(copy(line,StartPos+4,7));
EndPos := pos('</A>',Line)-1;
Line := copy(Line, StartPos+18, EndPos);
Line:= HTMLRemove(Line);
nome_filme:=Line;
PickTreeAdd(nome_filme, url);
LineNr := LineNr + 1;
End;
until (LineNr<1);
if PickTreeExec(Address) then begin
AnalyzeFilmPage(Address);
DisplayResults;
PickListClear;
if Input('Importar do DVDWorld', 'Escreva o nome do filme:', MovieName) then begin
//espaço não são permitidos
MovieName := StringReplace(MovieName, ' ', '%20');
AnalyzePage('http://dvdworld.com.br/dvdworld.hts?+se ... e+'+titulo');
I tryed to do a script to a Brazilian site
Muito obrigado, Guardião. Eu sei que vocês acham fácil fazer estes scripts, mas pra quem não sabe leva tempo (às vezes muito tempo...) para entender como funciona cada comando ou descobrir qual comando usar...
Outro bom site brasilleiro é http://adorocinema.cidadeinternet.com.br/filmes.htm, muito filmes, boas sinopses e fotos, não passei da primeira página
Muito obrigado de novo!
