[EN] AMC in Linux
nixke
[EN] AMC in Linux
Post by nixke »
Hy,
i'm currently still using Windows as OS, but i'm going to change to Linux. Can I still run AMC in Linux?
If i can't, are you planning on making a version of AMC for linux or not? It would be very usefull (AMC rulez)
vap_666@hotmail.com
Srry for the topic, just notised another topic with answers for my questions. I overlooked it the first time.
thx anyway. AMC rulez
Marcel
Running via Wine under Ubuntu Linux
Post by Marcel »
Since JanC quit working on the 'moviemeter-script' beacuse he was hooked on Linux, I was wandering if it worked on Linux too.
I just tried the moviemeter script, and it works like a charm
(just tested the import of a new movie!)
For the die hard addicts, you can try to install wine in your Linux distibution,
and then run this great piece of software made by Antoine.
So no 'port' is needed.
applaus voor Antoine [klap][klap][klap]
