xslt script and FireFox not working
alphenit
Post by alphenit »
Been using the Willspo script for a long time..very happy with it, I think the best script for ANT... just found out that Firefox doesn't display my movielist...
Is the xslt script also "designed" for Firefox or should I use another script..?
Many thanks in advance..!
Alphenit
Post by Alphenit »
Is there nobody than can be of some help ???
Looking for a script like the XSLT template that works with FireFox...
Thanks in advance...
card
Post by card »
Cool Willspo's template based on MSXML.
Wich browsers support this technology? MS Internet Explorer ONLY!
For using Firefox you (or Willspo or someone else) must almost completely rewrite "default.js".
Good idea - to make UNIVERSAL template for all browsers... :grinking:
AMEN! If I could I would but I can't :/
