[ENG] Modify the user-agent id of AMC ?
Is there a way to modify the user agent of AMC in a order to send a more anonymous id (i.e. without 'ant movie catalog') ?
thanks
It could be possible technically, but I do not really want to do that for a simple reason : if a site wants to block the program, he can do it currently. And I do not really want to have problems with sites owners because my program gets data from their site (if they ask me to stop to do it, currently I can simply answer them to block the user-agent of AMC)
