[NL] Custom script from several sites
This script does the following:
-Looks for the movie on moviemeter.nl and downloads all data
-Looks for the movie on IMDB and, fills in the website in the source field and downloads the rating ( I find IMDB more reliable)
-Downloads summary of Cinebel (NL) in the Commentary field
-Downloads a big HQ cover from DVDempire
This is my custom made script, just sharing for those who like it. It is compiled, tweaked and corrected from several other scripts. Credit for the original authors.
rolandb5
Post by rolandb5 »
DOh.. must not post being tired :(
This is the correct script
// GETINFO SCRIPTING
// MovieMeter.nl import script
 *      MovieMeter (NL), http://MovieMeter.nl/     *
 *  Now works with the new site !!                 *
 *  Written by JanC <amc-script@janc.cjb.net>      *
 *  (partially based on other import scripts)      *
 *   corrections by rolandb5@hotmail.com           *                                  *
 *  For use with Ant Movie Catalog                 *
 *  http://antp.be/software/moviecatalog           *
program MovieMeter;
  DescriptionToImport = 2;
  MovieName2: string;// variable voor de coverpage
  MovieURL: string;
//algemeen stuk
  result := -1;
  if StartAt < 0 then
    StartAt := 0;
      result := i;
function GetDescriptions(Address: string): string;
  Line, Value: string;
  BeginPos, EndPos,Longest: Integer;
  Result := '';
  Longest := 0;
  LineNr := FindLine('<p class="plotpar">', Page, 0);
  while LineNr > -1 do
    Value := '';
      if BeginPos > 0 then
        BeginPos := BeginPos + 10
        BeginPos := 1;
      EndPos := pos('</p>', Line);
      if EndPos < 1 then
        EndPos := Length(Line) + 1;
      if Value <> '' then
        Value := Value + ' ';
      LineNr := LineNr + 1;
    until (pos('</p>', Line) > 0) or (LineNr = Page.Count);
    HTMLDecode(Value);
    HTMLRemoveTags(Value);
    PickListAdd(Value);
    if Length(Value) > Longest then
      Result := Value;
      Longest := Length(Value);
    LineNr := FindLine('<p class="plotpar">', Page, LineNr);
procedure AnalyzePageIMDB(Address: string);
  if pos('<title>IMDb', Page.Text) = 0 then
    AnalyzeMoviePageIMDB(Page)
    AddMoviesTitles(Page, '<b>Exact Matches</b>');
    AddMoviesTitles(Page, '<b>Partial Matches</b>');
    AddMoviesTitles(Page, '<b>Approximate Matches</b>');
      AnalyzePageIMDB(Address);
//cinebel
procedure AnalyzePageCinema(Address: string);
  PageText: string;
  Block: string;
  ResultBlock: Integer;
  BeginPos, EndPos: Integer;
  ValueTitle, ValueAddress: string;
  PageText := GetPage(Address);
  if pos('<a href=/fr/film.asp', PageText) > 0 then
    //SetField(fieldURL, Address);
    AnalyzeMoviePageCinema(PageText)
    ResultBlock := Pos('<td class="cadre" height="16">', PageText);
    while ResultBlock > 0 do
      Delete(PageText, 1, ResultBlock + 35);
      EndPos := Pos('</td>', PageText);
      PickTreeAdd(StringReplace(Copy(PageText, 1, EndPos - 1), #13#10 + '                   ', ''), '');
      BeginPos := EndPos;
      EndPos := Pos('<td height="10"> </td>', PageText);
      Block := Copy(PageText, BeginPos, EndPos - BeginPos);
      Delete(PageText, 1, EndPos);
      BeginPos := Pos('<a href="/nl/film.asp', Block);
      while BeginPos > 0 do
        Delete(Block, 1, BeginPos - 1);
        EndPos := Pos('</a>', Block);
        ValueTitle := Copy(Block, 1, EndPos - 1);
        HTMLRemoveTags(ValueTitle);
        BeginPos := Pos('"', Block);
        EndPos := Pos('" class', Block);
        ValueAddress := 'http://www.cinebel.be' + Copy(Block, BeginPos + 1, EndPos - BeginPos - 1);
        PickTreeAdd(ValueTitle, ValueAddress);
        EndPos := Pos('</td>', Block);
        Delete(Block, 1, EndPos);
      AnalyzePageCinema(Address);
procedure AnalyzeMoviePageCinema(PageText: string);
  BeginPos := Pos('<table border="0" width="95%" cellpadding="0" cellspacing="0">', PageText);
  Delete(PageText, 1, BeginPos);
  // Description
  BeginPos := Pos('<hr noshade width="100%" size="1" color="#000000">', PageText);
  EndPos := Pos('<hr noshade width="100%" size="1" color="#000000">', PageText);
  Line := Copy(PageText, 1, EndPos - 1);
  BeginPos := Pos('>', Line);
  Delete(Line, 1, BeginPos);
  Line := StringReplace(Trim(StringReplace(Line, #13#10, '')), '<br>', #13#10#13#10);
  SetField(fieldComments, Line);
  DisplayResults;
//moviemeter
  I: Integer;
  // get movie page
  // get URL
  // find line with titles & year
  LineNr := 0;
  until Pos('<p class="kop">', Line) > 0;
  // get original(?) title
  BeginPos := Pos('<p class="kop">', Line);
  Delete(Line, 1, BeginPos-1);
  BeginPos := Pos('<p class="kop">', Line) + Length('<p class="kop">');
   EndPos := Pos('(', Line) - Length(' ');
  HTMLDecode(Value);
  Delete(Line, 1, EndPos);
  // get year
  BeginPos := Pos('(', Line) + Length('(');
  EndPos := pos(')', Line);
  HTMLDecode(Value);
  SetField(fieldYear, Value);
  // get first alternative title???
  BeginPos := Pos('Alternatieve titel:', Line) + Length('    Alternatieve titel:');
    if BeginPos > 0 then begin
    EndPos := pos('</b>', Line);
    HTMLDecode(Value);
  // find line with country, cat & length
  until Pos('geregisseerd door', Line) > 0;
  // get country
  BeginPos := 1;
  EndPos := Pos('<br>', Line);
  Value := StringReplace(Copy(Line, BeginPos, EndPos - BeginPos), #9, '');
  HTMLDecode(Value);
  Delete(Line, 1, EndPos + Length('<br>') - 1);
  // get category
  BeginPos := 1;
  HTMLDecode(Value);
  // get length
  BeginPos := 1;
  EndPos := Pos(' minuten <br>', Line);
  HTMLDecode(Value);
  SetField(fieldLength, Value);
  // find line with director & actors
  until Pos('<a href="?regisseur=', Line) > 0;
  // get director
  BeginPos := Pos('">', Line) + Length('">');
  EndPos := Pos('</a>', Line);
  HTMLDecode(Value);
  Delete(Line, 1, EndPos-1);
  // get actors
  BeginPos := Pos('<br>met ', Line) + Length('<br>met ');
  EndPos := Pos('</p><p>', Line);
  HTMLDecode(Value);
  SetField(fieldActors, Trim(Value));
  Value := '';
    // get line with description
    if Pos('</p>', Line) = 0 then begin
    Value := Value + Line;
    // get description
    if Pos('</p>', Line) > 0 then begin
      BeginPos := 1;
      EndPos := Pos('</p>', Line);
      Value := Value + Copy(Line, BeginPos, EndPos - BeginPos);
    HTMLDecode(Value);
  until Pos('</p>', Line) > 0;
  Value := StringReplace(Value, #9, '');
  // find line with cover picture
  until Pos('<img src="images/covers/', Line) > 0;
  // get cover picture
  BeginPos := Pos('<img src="', Line) + Length('<img src="');
  EndPos := Pos('" ', Line);
  GetPicture('http://www.moviemeter.nl/' + Value, False);
  // find line with rating
  until Pos('<td class="stembody">', Line) > 0;
  // get average rating (range 0.00-5.00 on the site, range 0-10 in AMC)
  BeginPos := Pos('<br>', Line) + Length('<br>');
  EndPos := Pos(' gemiddeld', Line);
  I := StrToInt(Copy(Value, 1, 1), 0) * 100 + StrToInt(Copy(Value, 3, 2), 0);
  Value := IntToStr(Round(I/50));
  SetField(fieldRating, Value);
  DisplayResults;
  MovieAddress: string;
  MovieTitle: string;
  StartPos, EndPos: Integer;
  // get results page
  // get redirect javascript
  Line := Page.GetString(Page.Count-1);
  // if only 1 movie found --> redirect to movie page
  if Pos('location.replace("?film=', Line) <> 0 then begin
    StartPos := Pos('?film=', Line);
    EndPos := Pos('");</script>', Line);
    MovieAddress := 'http://moviemeter.nl/' + Copy(Line, StartPos, EndPos - StartPos);
    AnalyzeMoviePage(MovieAddress);
  // more than 1 movie found
  else if Pos('location.href = "?searchresults"', Line) <> 0 then begin
    // get results page
    Page.Text := GetPage('?searchresults');
    // find line with results
    LineNr := 0;
    until Pos('<!--m-->', Line) > 0;
    // find individual results delimited by <!--m--> & <!--n-->'
    StartPos := Pos('<!--m-->', Line);
    while StartPos > 0 do begin
      Delete(Line, 1, StartPos-1);
      StartPos := Pos('<!--m-->', Line) + Length('<!--m--><a href="');
      EndPos := Pos('">', Line);
      MovieAddress := Copy(Line, StartPos, EndPos - StartPos);
      StartPos := Pos('">', Line) + Length('"><b>');
      MovieTitle := Copy(Line, StartPos, EndPos - StartPos);
      HTMLRemoveTags(MovieTitle);
      HTMLDecode(Movietitle);
      PickTreeAdd(MovieTitle, 'http://www.moviemeter.nl/' + MovieAddress);
    // if user picks a movie from the results list, import movie details
      AnalyzeMoviePage(Address);
  // no movies found
  else begin
    ShowMessage('Geen zoekresultaat voor "'+MovieName+'".');
// COVERSTUK
 function GetLines(Page: TStringList; LineNr: Integer): String;
var Value, Line: String;
    StartPos : Integer;
  Value := '';
  If Pos(' ',Line) > 0 Then Begin
    Value := StringReplace(Line, '•', '');
    HTMLDecode(Value);
        Value := Value + ',' + StringReplace(Line, '•', '');
        HTMLDecode(Value);
    until Pos(' ',Line) < 1
  result := Trim(Value);
procedure GetInfo(Page: TStringList; ItemID: String);
var Line, Value : String;
    LineNR, StartPos : Integer;
  // URL
 // SetField(fieldURL,'http://www.dvdempire.com/Exec/v4_item.asp?item_id=' + ItemID);
  //Rating
  LineNr := FindLine('<b>Rating:</b>', Page, 0);
  if LineNr > -1 then
    Line := Page.GetString(LineNr+3);
    StartPos := Pos('(<b>',Line)+4;
    Value := copy(Line, StartPos, pos('</b>', Line) - StartPos);
  //  SetField(fieldRating,Value);
  // Year
  LineNr := FindLine('<b>Production Year:</b>', Page, 0);
  if LineNr > -1 then
    StartPos := Pos('</b>',Line)+5;
    Value := Copy(Line, StartPos,4);
 //   SetField(fieldYear, Value);
  // Director
  LineNr := FindLine('<b>Directors:</b>', Page, 0);
  if LineNr > -1 then
    Value := GetLines(Page, LineNr+1);
  //  SetField(fieldDirector, Value);
  // Producer
  LineNr := FindLine('<b>Producers:</b>', Page, 0);
  if LineNr > -1 then
  //  SetField(fieldProducer, Value);
  // Actors
  LineNr := FindLine('<b>Actors:</b>', Page, 0);
  if LineNr > -1 then
  //  SetField(fieldActors, Value);
   // Description
  LineNr := FindLine('<b> Synopsis</b>', Page, 0);
  if LineNr > -1 then
    Value := Page.GetString(LineNr + 16)+Page.GetString(LineNr + 17)+Page.GetString(LineNr + 18);
    Value:=StringReplace(Value, '>i<', '> <');
    HTMLDecode(Value);
    //SetField(fieldDescription,Value);
  // Picture
  Line := 'http://images.dvdempire.com/gen/movies/' + ItemID + 'h.jpg';
  GetPicture(Line, False);
procedure AnalyzePageCOVER(Address: string);
  LineNr, StartPos, EndPos, L: Integer;
  ItemID, MovieAddress, MovieTitle : string;
  LineNr := FindLine('<title>DVD Empire - Item -', Page, 0);
  if LineNr >-1 then begin
    LineNr := FindLine('item_id', Page, 0);
    Line := Trim(Page.GetString(LineNr));
    StartPos := pos('item_id=', Line) + 8;
    ItemID := copy(Line, StartPos, pos('&tab=', Line) - StartPos);
    GetInfo(Page,ItemID);
  end else begin
    LineNr := FindLine('Matches Found<br>', Page, 0);
      StartPos := pos('<b>', Line) + 3;
      L := StrToInt('0'+ Copy(Line, StartPos, pos('</b>', Line) - StartPos),1);
      PickTreeAdd(IntToStr(L)+' Matches found', '');
      If L>0 Then begin
        // Find Films
          LineNr := FindLine('searchID=', Page, LineNr);
            If pos('<img src="', Line) <1 Then Begin
              ItemID := copy(Line, StartPos, pos('">', Line) - StartPos);
              MovieAddress := 'http://www.dvdempire.com/Exec/v4_item.asp?item_id=' + ItemID;
              MovieTitle := copy(Line, StartPos, 500);
        until (LineNr <1 );
      ItemID :=copy(Address, 51, 8);
  DisplayResults;
//IMDB Onderdeel
procedure AddMoviesTitles(Page: TStringList; Tag: string);
  StartPos: Integer;
  LineNr := FindLine(tag, Page, 0);
  if LineNr > -1 then
    HTMLRemoveTags(Line);
    PickTreeAdd(Trim(Line), '');
    LineNr := LineNr + 5;
      StartPos := pos('href="', Line) + 5;
      Delete(Line, 1, StartPos);
      MovieAddress := Copy(Line, 1, pos('">', Line) - 1);
      StartPos := Pos('">', Line) + 2;
      MovieTitle := Copy(Line, StartPos, Pos('</a>', Line) - StartPos);
      PickTreeAdd(MovieTitle, 'http://us.imdb.com' + MovieAddress);
      LineNr := LineNr + 2;
    until Pos('</table>', Line) > 0;
procedure AnalyzeMoviePageIMDB(Page: TStringList);
  BeginPos, EndPos, DescrImport: Integer;
  DescrImport := DescriptionToImport;
  if (DescrImport <> 1) and (Pos('<a href="plotsummary">', Page.Text) = 0) then
    DescrImport := 1;
  MovieURL := 'http://imdb.com/title/tt' + Copy(Page.Text, Pos('?pending&add=', Page.Text) + 17, 7);
  // URL
  SetField(fieldSource, MovieURL);
  // Rating
  if LineNr > -1 then
    if Pos('/10', Line) > 0 then
  DisplayResults;
//  Programma Aanroep deel
  if CheckVersion(3,4,0) then     // is this really the minimum version?
    if Input('MovieMeter.nl Import', 'Geef de titel van de film:', MovieName) then
      if pos('  ', MovieName)>0 then MovieName:=StringReplace(MovieName, '  ', '');// voor eigen gebruik
      AnalyzeResultsPage('http://moviemeter.nl/?search&q='+UrlEncode(MovieName));
      AnalyzePageIMDB('http://us.imdb.com/Tsearch?title='+UrlEncode(MovieName));
      if pos(', The', MovieName)>0 then MovieName:=StringReplace(MovieName, ', The', '');
      if pos(',The', MovieName)>0 then MovieName:=StringReplace(MovieName, ',The', '');
      AnalyzePageCinema('http://www.cinebel.be/nl/srch.asp?mot='+UrlEncode(MovieName));
      // code voor de coverpage
      MovieName2:=MovieName;
      MovieName:=StringReplace(MovieName, '’', Chr(39));
      MovieName:=AnsiLowerCase(MovieName);
      MovieName:=AnsiUpFirstLetter(MovieName);
      if pos('The ', MovieName)=1 then MovieName:=StringReplace(MovieName, 'The ', '');
      AnalyzePageCOVER('http://www.dvdempire.com/Exec/v5_search_item.asp?string='+UrlEncode(MovieName));
I remove the "incorrect" one from the first post.
So this one is different than the one you posted on the other topic ? There is something strange at the end ; I guess that the few lines after the "end." should be deleted...
rolandb5
Post by rolandb5 »
this is indeed another script. though based on the other one.
You were correct on the code, should be removed, but it works when it is included.
It's because in Pascal & Delphi all what's after the "end." is simply ignored
Bonus
Post by Bonus »
Can anyone make this one working?
Thx in advance!
