Multiple categories + exporting
Wermine
Post by Wermine »
Someone posted here script, which gets multiple genres from IMDb instead of just one. That works perfectly and I use it. You can see multiple genres in action here:
http://collectum.urli.net/ (select "all" so you see those genres too)
Now, if I want to export my movies in html file organisized by genre I face following problem:
As you may see I have only one movie with "Drama / Fantasy / Adventure" and so on. Now what I want is two things. I asked this one before and I got answer too, thanks (ability to export multiple templates with multiple settings). But another is that I can export all movies with with a word "Adventure" in their genre to some html site with some template.
If we get that "multiple templates and multiple html files at once" feature some day, I can list all "Adventure" movies in one place and all "Drama" movies in another. Of course now we would get same movie in two different categorie pages, but that's ok.
You can use the search functionnality to show all movies that have "adventure" in their "category" field.
I won't make a so specific feature as something based on categories for individual exports.
But when one day I will add scriped export, then things like that would be possible, I think.
The only problem is that I do not know when I'll add this scripting export thing :/
