Sort by Viewed
Sort by Viewed
This is a great program. I think it is the best I have seen for cataloging. Is there a way to indicate that I have viewed a film so that I can just sort out the films I have already seen?
A solution is to use one of the fields that you do not use currently to store this info.
You can also use list's checkboxes (Tools -> Preferences -> Movie list -> Checkboxes to enable them) but until version 3.5 you can't easily get the list of checked or unchecked movies.
Should I try version 3.5? Would that be better for what I want to do? I have already downloaded it.
Merci pour la response
The current 3.5 "alpha" has a bug that makes the "group by" feature crash. So it will not help you much more I think. I hope to release a new beta version soon, maybe next weekend, before end of month anyway.
