[NL] Moviemeter update
rolandb5
Post by rolandb5 »
The original title stopped working as well as the alternative titel.
Fixed that and also corrected the rating procedure.
rolandb5
Post by rolandb5 »
left a testing variable in the code, this is the correct code
edit: new version bellow
Thanks ;)
I added the [code] ... [/code] tags so the script keeps its formatting (spaces in front of the lines)
Roland, bedankt man... (JoopBraakhekke)
CyMo
Post by CyMo »
One more other thing besides the title ...... it doesn't show the duration (duur) of the movie any longer :??:
rolandb5
Post by rolandb5 »
// GETINFO SCRIPTING
// MovieMeter.nl import script
 *      MovieMeter (NL), http://MovieMeter.nl/     *
 *  Now works with the new site !!                 *
 *  Written by JanC <amc-script@janc.cjb.net>      *
 *  (partially based on other import scripts)      *
 *   corrections by rolandb5@hotmail.com           *                                  *
 *  For use with Ant Movie Catalog                 *
 *  http://antp.be/software/moviecatalog           *
program MovieMeter;
  Line, Value: string;
  I: Integer;
  BeginPos, EndPos: Integer;
  // get movie page
  // get URL
  // find line with titles & year
  LineNr := 0;
    LineNr := LineNr + 1;
  until Pos('<p class="kop">', Line) > 0;
  // get original(?) title
  BeginPos := Pos('<p class="kop">', Line);
  Delete(Line, 1, BeginPos-1);
  BeginPos := Pos('<p class="kop">', Line) + Length('<p class="kop">');
   EndPos := Pos('(', Line) - Length(' ');
  HTMLDecode(Value);
  Delete(Line, 1, EndPos);
  // get year
  BeginPos := Pos('(', Line) + Length('(');
  EndPos := pos(')', Line);
  HTMLDecode(Value);
  SetField(fieldYear, Value);
  // get first alternative title???
  BeginPos := Pos('Alternatieve titel:', Line) + Length('    Alternatieve titel:');
    if BeginPos > 0 then begin
    EndPos := pos('</b>', Line);
    HTMLDecode(Value);
  // find line with country, cat & length
  until Pos('geregisseerd door', Line) > 0;
  // get country
  BeginPos := 1;
  EndPos := Pos('<br>', Line);
  Value := StringReplace(Copy(Line, BeginPos, EndPos - BeginPos), #9, '');
  HTMLDecode(Value);
  Delete(Line, 1, EndPos + Length('<br>') - 1);
  // get category
  BeginPos := 1;
  HTMLDecode(Value);
  // get length
  BeginPos := 1;
  EndPos := Pos(' minuten <br>', Line);
  HTMLDecode(Value);
  SetField(fieldLength, Value);
  // find line with director & actors
  until Pos('<a href="?regisseur=', Line) > 0;
  // get director
  BeginPos := Pos('">', Line) + Length('">');
  EndPos := Pos('</a>', Line);
  HTMLDecode(Value);
  Delete(Line, 1, EndPos-1);
  // get actors
  BeginPos := Pos('<br>met ', Line) + Length('<br>met ');
  EndPos := Pos('</p><p>', Line);
  HTMLDecode(Value);
  SetField(fieldActors, Trim(Value));
  Value := '';
    // get line with description
    if Pos('</p>', Line) = 0 then begin
    Value := Value + Line;
    // get description
    if Pos('</p>', Line) > 0 then begin
      BeginPos := 1;
      EndPos := Pos('</p>', Line);
      Value := Value + Copy(Line, BeginPos, EndPos - BeginPos);
    HTMLDecode(Value);
  until Pos('</p>', Line) > 0;
  Value := StringReplace(Value, #9, '');
  // find line with cover picture
  until Pos('<img src="images/covers/', Line) > 0;
  // get cover picture
  BeginPos := Pos('<img src="', Line) + Length('<img src="');
  EndPos := Pos('" ', Line);
  GetPicture('http://www.moviemeter.nl/' + Value, False);
  // find line with rating
  until Pos('<td class="stembody">', Line) > 0;
  // get average rating (range 0.00-5.00 on the site, range 0-10 in AMC)
  BeginPos := Pos('<br>', Line) + Length('<br>');
  EndPos := Pos(' gemiddeld', Line);
  I := StrToInt(Copy(Value, 1, 1), 0) * 100 + StrToInt(Copy(Value, 3, 2), 0);
  Value := IntToStr(Round(I/50));
  SetField(fieldRating, Value);
  DisplayResults;
  MovieAddress: string;
  MovieTitle: string;
  StartPos, EndPos: Integer;
  // get results page
  // get redirect javascript
  Line := Page.GetString(Page.Count-1);
  // if only 1 movie found --> redirect to movie page
  if Pos('location.replace("?film=', Line) <> 0 then begin
    StartPos := Pos('?film=', Line);
    EndPos := Pos('");</script>', Line);
    MovieAddress := 'http://moviemeter.nl/' + Copy(Line, StartPos, EndPos - StartPos);
    AnalyzeMoviePage(MovieAddress);
  // more than 1 movie found
  else if Pos('location.href = "?searchresults"', Line) <> 0 then begin
    // get results page
    Page.Text := GetPage('?searchresults');
    // find line with results
    LineNr := 0;
    until Pos('<!--m-->', Line) > 0;
    // find individual results delimited by <!--m--> & <!--n-->'
    StartPos := Pos('<!--m-->', Line);
    while StartPos > 0 do begin
      Delete(Line, 1, StartPos-1);
      StartPos := Pos('<!--m-->', Line) + Length('<!--m--><a href="');
      EndPos := Pos('">', Line);
      MovieAddress := Copy(Line, StartPos, EndPos - StartPos);
      StartPos := Pos('">', Line) + Length('"><b>');
      MovieTitle := Copy(Line, StartPos, EndPos - StartPos);
      HTMLRemoveTags(MovieTitle);
      HTMLDecode(Movietitle);
      PickTreeAdd(MovieTitle, 'http://www.moviemeter.nl/' + MovieAddress);
    // if user picks a movie from the results list, import movie details
      AnalyzeMoviePage(Address);
  // no movies found
  else begin
    ShowMessage('Geen zoekresultaat voor "'+MovieName+'".');
  if CheckVersion(3,4,0) then     // is this really the minimum version?
    if Input('MovieMeter.nl Import', 'Geef de titel van de film:', MovieName) then
      AnalyzeResultsPage('http://moviemeter.nl/?search&q='+UrlEncode(MovieName));
    ShowMessage('Dit script vereist een nieuwere versie van Ant Movie Catalog (minstens versie 3.4.0)');
rolandb5
Post by rolandb5 »
Sorry, Antp, ruined your layout again. Forget a ].
This must solve all problems.
no problem, I edited your message to add the missing "]" ;)
Thanks for the script update
CyMo
Post by CyMo »
Works like a charm again :grinking:
Thanks for the quick update and for the beautiful script
It safes so much time
It doesn't work for me. Whatever title I try to add, it keeps saying 'no search results'. What am I doing wrong?
rolandb5
Post by rolandb5 »
Don;t know, still works here as a charm. Maybe you didn;t copy-paste the script correct?
Hmmm, I switched off my firewall, and now it's working like a charm indeed! That's very strange, because other scripts like IMDB and Amazon are working OK with the firewall on!
