Exporting to Excel
ravendark
Exporting to Excel
Post by ravendark »
Yes,
I'd like to know if there's a way to export Ant Movie Catalog to Excel Or Word.
yes, simply export to CSV and then open the CSV file with Excel ;)
You may have to switch the values of "delimiter" fields in AMC's export window if the columns are not properly recognized by Excel.
