Export
Twink
Export
Post by Twink »
Ability to export/print by borrower. So I can make a list of what I have lent out, or ones I have still. (I made a special borrower called Broken, would make it very useful).
Sure, I have to add export options, e.g. possibility to select which movies have to be exported, like in the Print window, wil be for version 4 or 4.1
