Another suggestion
Corvin
Another suggestion
Post by Corvin »
Please tell can you do multiple lines for subtitles and languages as usually normal DVD has more than one language and more than one subtitle language?
A lot of thanks from Russia.
Currently you have to put all the values separated by commas or slashes for example.
In a future version it will be managed properly.
Corvin
Post by Corvin »
Ok! I`ll be waiting...
