New German Script (Combined OFDb/IMDb Script)
Bad Joker
Post by Bad Joker »
hey folks
i did a new script for all the german users, with the next update the script should be within the installation package.
it's a combined script which uses first ofdb to get the title and then get there the description and the imdb url, and then all the other stuff from the imdb site.
it gets from ofdb:
-german description
-(german imdb) url
and then from imdb:
-executive producer
-german translated/original title
-director
-actors
-year
-rating (does not round the value anymore, just gets the first number from the x.x value)
-country
-category
if you find any bugs or you just have some suggestion, tell me ;)
http://scorpius.spaceports.com/~badjoke ... Db(DE).ifs
there you can get the script
Re: New German Script (Combined OFDb/IMDb Script)
Bad Joker wrote: with the next update the script should be within the installation package.
I should did that on Monday, but I forgot, and yesterday I did not had time for that.
It will be done today or Friday ;)
eternal
Post by eternal »
hi
i really would appreciate if u please could implement a function to get "the small movie pic" and the "movie lenght"
anyways, awesome work dude, thx
eternal
PS: ant movie catalog simply owns :)
Bad Joker
Post by Bad Joker »
hey
you could do that at your own, just add the script parts from the imdb script (pic import and lenght) to my script and voila ;)
eternal
Post by eternal »
well, i did as you said and it works ;)
thx for the small hint, wouldn't have thought of that possibility to edit the script myself
eternal
MasterBlaster
Post by MasterBlaster »
Hi Bad Joker,
I extend your script to a "MasterBlaster OFDb-IMDb (DE)" script.
But I have a problem to extend the script with the "fieldMadiaLabel" Field.
I use this Field for the certificates information
(in Germany like FSK 12 = Free Self Control 12 ) :-)
but every time I run the script, I get an error that the
"fieldMediaLabel" isn't usable.
Do you have any idea ?
MasterBlaster
PS: In the first Script it was an error about the rating.
[quote="Bad Joker"]hey folks
If I remember well it is fieldMedia and not fieldMediaLabel
For the rating error, if it comes from IMDB, replace
if Pos('awaiting', Line) = 0 then
by
if Pos('/10', Line) > 0 then
So, at first thx for this script. But now I wan't to extend your script with a pic-search. I've add the script part from the imdb script. The URL is: "http://images.amazon.com/". This works fine, but I need the german covers, so I have to connect to "http://eu-images.amazon.com/". But it doesn't function. Do you have an idea, why not?
1 more question:
How I can use "www.darktown.com" for my pics?
thx
Bad Joker
Post by Bad Joker »
sure is there a way, but please try to understand "how" the imdb script works and then create one for darktown or amazon on yourself, i thing this will be a big piece of work to add that :)
so i hop you understand, why i don't do it...
also i'm wainting to import urls into the movie database instead of saving all images to disk, will be much better ;)
good joker
Post by good joker »
hi
could you add the large pic from the imdb or a german pic (with the german text on it)(equal quality)
Bad Joker
Post by Bad Joker »
this is really easy
just add the code from the "imdb large" pic script to the "ofdb - imdb" script from me :)
here is the code:
// Picture
  LineNr := FindLine('<img alt="cover" align="left" src="http://posters.imdb.com/', Page, 0);
  if LineNr < 0 then
  if LineNr > -1 then
    BeginPos := pos('src="', Line) + 4;
    Delete(Line, 1, BeginPos);
    EndPos := pos('"', Line);
    Value := StringReplace(Value, 'MZZZZZZZ', 'LZZZZZZZ'); // change URL to get the Large instead of Small image
    GetPicture(Value, False); // False = do not store picture externally ; store it in the catalog file
add it under the "procedure AnalyseIMDBPage(Page: TStringList);"
part
good joker(bad name)
Post by good joker(bad name) »
:grinking: thx
Hi, you're right. I have seen, that it will be a big piece of work to add other cover-pages.
Okay, I'll try it. Now I've add the function to search in amazon.com and imdb.com for pics if the script does not find a pic in ofdb. It's very simple, but for me its really okay, FOR NOW :)
// GETINFO SCRIPTING
// Combined OFDb / IMDb (DE) import with description from OFDb. All other informations from IMDb
 *  Online-Filmdatenbank(OFDb), 	                 *
 *   http://www.ofdb.de                            *
 *            and                                  *
 *  Internet Movie Database (IMDb),                *
 *   http://us.imdb.com                            *
 *  (c) 2002 Fabian Filipczyk    FFJaro@gmx.de     *
 *     Modified by Bad Joker    badjoker@gmx.net   *
 *     Pic Import by Frau Holle                    *
program OFDB_DE;
  MovieName, IMDbURL, GerIMDbDURL : string;
  PicDa : integer;
  OFDB_Server = 'http://ofdb.persephone.net-build.de/';
  PicNotAvabOFDB = 'http://www.hsi-infopool.de/zensur/movies/images/film/na.gif';
  result := -1;
  if StartAt < 0 then
    StartAt := 0;
      result := i;
procedure AnalysePage(Address: string);
  if pos('<title>OFDb - Übersicht der Filmdaten</title>', Page.Text) > 0 then
    AnalyseOFDBPage(Page)
    AnalyseIMDBDPage(Page)
    AnalyseIMDBPage(Page)
    DisplayResults
    if pos('Titel:</b><br><br><b>&#149;</b> <i>Keine Ergebnisse</i>', Page.Text) > 0 then
      ShowMessage('Keine Ergebnisse unter dem Titel zu finden, bitte den Titel des Filmes ändern!');
      Input('OFDb', 'Bitte einen alternativen Titel eingeben :', MovieName);
      AnalysePage(OFDB_Server + 'view.php?page=suchergebnis&SText='+UrlEncode(MovieName)+'&Kat=All');
    LineNr := FindLine('<b>Titel:</b>', Page, 0);
    if LineNr > 0 then
    begin PickTreeAdd('Filme:', '');
         AnalysePage(Address);
  StartPos, EndPos: Integer;
    StartPos := pos('<a href=''view.php?page=film&fid=', Line);
    if StartPos > 0 then
      Delete(Line, 1, StartPos + 8);
      MovieAddress := copy(Line, 1, pos('''>', Line) - 1);
      StartPos := pos('''>', Line) +2;
      MovieTitle := copy(Line, StartPos, pos('</a>', Line) - StartPos);
      HTMLRemoveTags(MovieTitle);
      PickTreeAdd(MovieTitle , OFDB_Server + MovieAddress);
  until (StartPos < 1);
procedure AnalyseOFDBPage(Page: TStringList);
  Line, Temp, Value: string;
  LineNr, BeginPos, EndPos: Integer;
  // Get IMDb URL + Set german IMDb URLs
    LineNr :=Findline('http://german.imdb.com/Title?', Page, 0);
    BeginPos := pos('german.imdb.com/Title?', Line)-7;
    EndPos := pos('target', Line)-2;
    SetField(fieldURL, Value);
    BeginPos := pos('Title?', Line)+6;
    Temp := copy(Line, BeginPos, EndPos - BeginPos);
    Value := ('http://german.imdb.com/Details?' + Temp);
    GerIMDbDURL := Value;
    Value := ('http://us.imdb.com/Title?' + Temp);
    IMDbURL := Value;
  // Picture
  LineNr := FindLine('http://www.hsi-infopool.de/zensur/movies/images/film', Page, 0);
  if LineNr > -1 then
      if Value = PicNotAvabOFDB then
      PicDa := 1
        PicDa := 0;
  // Description
  LineNr := Findline('<b>Inhalt:</b>', Page, 0);
  if LineNr > -1 then
    LineNr :=Findline('<a href=''view.php?page=inhalt', Page, 0);
    BeginPos := pos('<a href=''view.php?page=inhalt', Line)+9;
    EndPos := pos('''><b>[mehr]', Line);
    GetDescriptions(Value);
procedure GetDescriptions(Address: string);
  Temp:= '';
  Page.Text := GetPage(OFDB_Server + Address);
  LineNr := FindLine('Eine Inhaltsangabe von', Page, 0);
  if LineNr > -1 then
    BeginPos := pos('</a></b><br><br>', Line) + 16;
    while (pos('<br />', Line) >0) do
           EndPos := pos('<br />', Line);
           Temp := Temp + copy(Line, BeginPos, EndPos - BeginPos);
           LineNr:=LineNr+1;
           Line:=Page.GetString(LineNr);
           BeginPos:=1;
    EndPos := pos('</font></p>', Line);
    Temp:= Temp +  copy(Line, BeginPos, EndPos - BeginPos);
    Value:= Temp;
procedure AnalyseIMDBDPage(Page: TStringList);
  Line, Value, Value2, FullValue, GerTitle, Ger, Temp: string;
  BeginPos, EndPos, LineNr, TempPos: Integer;
  Page.Text := GetPage(GerIMDbDURL);
  //Producer
  LineNr := FindLine('<a name="producers"', Page, 0);
  if LineNr > -1 then
    FullValue := '';
    EndPos := 0;
    BeginPos := Pos('<b class="blackcatheader">Produktion', Line);
    EndPos := Pos('<a name="music_original"', Line);
    if EndPos = 0 then
    EndPos := Pos('<a name="cinematographers"', Line);
    Line := copy(Line, BeginPos, EndPos - BeginPos);
      BeginPos := Pos('<td valign="top">', Line);
      if BeginPos > 0 then
        Delete(Line, 1, BeginPos + 25);
        TempPos := Pos('">producer</a>', Line);
        if (TempPos > 0) and (TempPos < Pos('</tr>', Line)) then
          EndPos := pos('</a>', Line);
          if EndPos = 0 then
            EndPos := Pos('</td>', Line);
          if FullValue <> '' then
          Delete(Line, 1, EndPos);
        Line := '';
    until Line = '';
    HTMLDecode(FullValue);
    SetField(fieldProducer, FullValue);
  // Translated Title
  LineNr := FindLine('<i class="transl">', Page, 0);
  if LineNr > -1 then
      Ger := '';
      LineNr := LineNr - 1;
      LineNr := LineNr + 1;
        if Pos('[de]', Line) or Pos('(Germany)', Line) > 0 then
        BeginPos := pos('class="transl">', Line) + 14;
        EndPos := pos('[de]', Line);
        Ger := copy(Line, BeginPos, EndPos - BeginPos);
      until (pos('<b class="ch">', Line) > 0 );
      BeginPos := pos('>', Ger) + 1;
      EndPos := pos('(', Ger) - 1;
      GerTitle := copy(Ger, BeginPos, EndPos - BeginPos);
      HTMLDecode(GerTitle);
      SetField(fieldTranslatedTitle, GerTitle);
  BeginPos, EndPos, LineNr: Integer;
  // Picture
  if PicDa = 1 then
    if LineNr < 0 then
    if LineNr > -1 then
  // Original Title & Year
  Page.Text := GetPage(IMDbURL);
  if LineNr > -1 then
    BeginPos := pos('<title>', Line);
      BeginPos := BeginPos + 7;
      EndPos := pos('(', Line);
    if EndPos = 0 then
      EndPos := Length(Line);
    HTMLDecode(Value);
      EndPos := pos(')', Line);
      SetField(fieldYear, Value);
  // Rating
  if LineNr > -1 then
      EndPos := BeginPos + 1;
      SetField(fieldRating, Value);
  // Director
  if LineNr > -1 then
    FullValue := '';
    until Pos('</a>', Line) = 0;
  // Actors
  LineNr := FindLine('Cast overview', Page, 0);
  if LineNr = -1 then
    LineNr := FindLine('cast overview', Page, 0);
  if LineNr = -1 then
    LineNr := FindLine('Credited cast', Page, 0);
  if LineNr = -1 then
    LineNr := FindLine('Complete credited cast', Page, 0);
  if LineNr > -1 then
    FullValue := '';
        if EndPos = 0 then
          BeginPos := pos('.... </td><td valign="top">', Line);
            EndPos := pos('</td></tr>', Line);
            BeginPos := BeginPos + 27;
            if Value2 <> '' then
              Value := Value + ' (als ' + Value2 + ')';
        Line := '';
    until Line = '';
  //Country
  LineNr := FindLine('Country:', Page, 0);
  if LineNr > -1 then
    HTMLDecode(Value);
  //Category
  LineNr := FindLine('Genre:', Page, 0);
  if LineNr > -1 then
    HTMLDecode(Value);
  // Length
  LineNr := FindLine('Runtime:', Page, 0);
  if LineNr > -1 then
    EndPos := pos(' min', Line);
    if EndPos = 0 then
      EndPos := pos('  /', Line);
    if EndPos = 0 then
    if Pos(':', Line) < EndPos then
      BeginPos := Pos(':', Line) + 1
      BeginPos := 1;
    SetField(fieldLength, Value);
  if CheckVersion(3,4,0) then
    if (MovieName <> '') or Input('OFDb', 'Bitte Titel eingeben :', MovieName) then
    ShowMessage('Dieses Script benötigt eine neuere Version von Ant Movie Catalog (mindestens Version 3.4.0)');
Anonymous wrote:Hi, you're right. I have seen, that it will be a big piece of work to add other cover-pages.
* and *
program OFDB_DE;
PicDa : integer;
PicNotAvabOFDB = 'http://www.hsi-infopool.de/zensur/movie ... ilm/na.gif';
result := -1;
if StartAt < 0 then
StartAt := 0;
result := i;
DisplayResults
if LineNr > 0 then
IMDbURL := Value;
// Picture
if LineNr > -1 then
PicDa := 1
PicDa := 0;
// Description
if LineNr > -1 then
Temp:= '';
if LineNr > -1 then
LineNr:=LineNr+1;
BeginPos:=1;
Value:= Temp;
//Producer
if LineNr > -1 then
FullValue := '';
EndPos := 0;
if EndPos = 0 then
if EndPos = 0 then
Line := '';
until Line = '';
// Translated Title
if LineNr > -1 then
Ger := '';
// Picture
if PicDa = 1 then
if LineNr < 0 then
if LineNr > -1 then
if LineNr > -1 then
if EndPos = 0 then
HTMLDecode(Value);
// Rating
if LineNr > -1 then
// Director
if LineNr > -1 then
FullValue := '';
// Actors
if LineNr = -1 then
if LineNr = -1 then
if LineNr = -1 then
if LineNr > -1 then
FullValue := '';
if EndPos = 0 then
Line := '';
until Line = '';
//Country
if LineNr > -1 then
HTMLDecode(Value);
//Category
if LineNr > -1 then
HTMLDecode(Value);
// Length
if LineNr > -1 then
if EndPos = 0 then
if EndPos = 0 then
BeginPos := 1;
I do not know why you quoted your post, I guess I should delete it ? (it takes lots of space on the page :D)
I edited the first of the two post to put the code between
 tags, to make it more readable.
PS: if you register on the forum you can edit your posts ;)
hansi
Post by hansi »
i wonder if someone please could include a new "get large picture" method, because since imdb lately changed their web page the large picture doesnt work anymore and i dont get the the code from the "large picture beta topic" to work because this script uses imdb and ofdb. i am really sorry to bother, but i am not that good with such scripting stuff, can hardly use notepad.
i hope someone will help me
cu and thx in advance
Bad Joker
Post by Bad Joker »
just add that beta picture thing under the "//Category" part and set the variables in the "AnalyseIMDBPage" procedure, thats all
if you got problems, ask me via mail
If you modified the OFDB scripts, can you send me the updated version ? Thanks :)
Hi BadJoker !
First at all a big thank you for the great job you did with this script :grinking:
But I've problems importing the movie "Ali" with Will Smith. Can you give me a hint how I can get the facts of this movie with your script, please ? Typing "Ali" gives to much results... :cry:
Thx & greetings,
Fred.
