Suggestion for Line Breaks for larg data bass
lepus
Post by lepus »
Hi I have a very large Movie list that right now covers 4 CD folders and working on the 5 one now, the CD folders each holds 264 movies. Right now I have them all in one list very large list which starts at number one all the way to the end. What I was wondering is if there is a way to split the file like at number 264 and then add a LINE Break with a title for the Line Break? Then be able to start the numbers from 1 to 264 and add another line break and keep doing this for each CD folder but keep it all in the same data bass? The only way I can think of doing this is by making a new data bass for each CD Folder, but then you have to load each data bass separately when you won’t to look up some thing and that will be a pain. I just won’t to keep it all on one file and just use line breaks if this is possible.
Thanks this is the best program out there.
Currently it is not possible, and do not know yet if I will add things like that
