Some Suggestions
TBCdevil
Some Suggestions
Post by TBCdevil »
first of all congratz with this excellent piece of soft its amazing :grinking:
I had some suggestions so here i go:
Add/remove (custom) records: many people have different ways of storing there information. I personnally miss a location number, all my movies have a specific number so they can easely be found.
Add a Smartlist: itunes style :) its the option to make a list with (a) specific querie(s) if i'm correct. for example a list called "johnny depp" and it shows all the movies made with johnny depp. in your "find" tool u can for example save your results to a smartlist.
Mass add files in folder and subfolder.
Mass edit files, why? because sometimes when you import a DB from someone else then you would want to make all those files belong to the owner so that they won't get mixed up. the progam the godfather (a MP3 tag/renamer ) has got these great capabilities.
that's what i miss :)
keep it up.
Custom records : maybe later, but I do not promise anything. But in version 3.6 or 4 I will add at least some fields like Media Number, Box Number, etc. Until then you have to use Movie Number and Media Label ;)
Saved queries : why not, but not before few versions since I have more important things to add
Mass add files : it will arrive soon ; maybe in 3.5
Mass edit : can be easily done by custom script of few lines. ScorEpioN made a script that helps that too, it is included in latest version (called "update all fields" or something like that)
