mass update from imdb??
limbo74
Post by limbo74 »
can't we do mass update for our divx list from imdb..? i mean shold i have to select 1 item and "get information" for tha item and another and another.. i have 307 fimz and cant make that like it?..
am i doin smth wrong or theres no mass update from imdb?..
urs sincerly..
Limbo
For mass update you have to use Tools -> Scripting, and then it allows to select to which movies apply the scripting. In this mode you cannot select which field that are modified (you have to modify the script for that).
