Hi all,
is it possible to view the support type (other than the movie name) on the list of the movies on the print page ?
It should be useful to select the corretct print template ...
thanks
bye !!
Support type on print page
SteM
Yes, i know !
But when i open the movie list to print some covers, i must remember the type of support to select the correct kind of template (ex. the movie is stored on a DVD case i will print a DVD case template, and so on).
This information must be remembered by the user ....
So I think it should be useful to view the support type other than the movie title ...
Thanks a lot !
Thanks a lot !
OK, I did not understood your question
Well, it is easier to select the movies to print from the main window (e.g. group them by Media Type and then select only one of the group) and then call the print window.
Anyway, in version 3.5 the movie list of the print window has been removed : you can only select to print selected movies, all movies or checked movies. I think it is easier like that, and it is not really useful to build a replica of the movie list in the print window rather than take the selection of the main window.
