Just wanted to report that, in the Report Designer, I can't turn the text orientation 180 degrees.... It just won't do it... (it would put the text upside down)...
I'm REALLY needing this feature, since I'm trying to make a template for printing envelopes for CDs, and half the envelope must be printed upside down...
Hope you can fix this...
Thanks for your time!
Gastón.
ARGENTINA
BUG in the Report Designer
El Ga
El Ga
Just to explain myself better, in the front face of the envelope I put the picture...
When I tried to rotate the whole template, to make it in landscape style, I had no problem with the text, but I had to rotate the image 90 degrees, and I couldn't....
It's a real shame, because the report option is the GREATEST....
If you can work this problem out, it'll be great...
Thanks again for your time.
El Ga
