OFDB small pic does not work
Knorki
Post by Knorki »
Hello,
OFDB DE isn´t working for me. I only get the original and the translated title and some html code about a font ion the country field. Not more.
But when I look on their internet page, there is every info stored.
Can someone correct the script, I´m not so goog in that.
Many thanks
Stefan :cry:
GoofySGR
Post by GoofySGR »
Hello Knorki,
i have the same Problem since 2 day's.
I think ofdb has change the Page layout.
I hope that someone can fix it.
DarkS
Post by DarkS »
Hello,
i've corrected the script and tested it with a couple of movies. it worked fine for me. i hope it works now for everyone.
now the question is how can i upload the file here (if its possible at all)? if not then i will post the entire code here. then you can copy and paste it.
jean
c&p
Post by jean »
hi, please poste the code. thanks for that.
The best solution would be to send it to me by e-mail so I upload it on www.antp.be/temp/scripts/ until next update ;)
Thanks for DarkS for sending it by e-mail ; here is it :
http://www.antp.be/temp/scripts/OFDb%20(DE).ifs
@antp
you have new mail
@jean
i've send the file to antp. you can download the script from www.antp.be/temp/scripts/ as soon as he uploads it.
I was faster than you, and you forgot to login with your nickname :p
a lot. works very fine an you are some fast guys :grinking:
i´ve posted this as a new topic. sorry, i can´t delete.
jean
Post by jean »
last from me, jean.
it seems i am to excited about the fine working script! ;)
DarkS
Post by DarkS »
@antp
yepp. that was my fault. i saw your posting after i submit mine :)
julakali
time?
Post by julakali »
what about importing the time?
would be very nice too i think...
DarkS
Post by DarkS »
do you mean the length of the movie? imho its not that easy to implement. there is no official field "length" on the page. the length is only stated (sometimes) in the description of the different dvd or video versions. and the length is quite often different. how do you want to decide which one you need? i think the best way to import the movie length is to insert it manually.
frank
Post by frank »
thx 4 fixing this
frank
Bad Joker
Re: time?
Post by Bad Joker »
julakali wrote:what about importing the time?
you can use the ofdb / imdb script for the lenght...
