cannot create log folder
mo
Post by mo »
When I try to inmport information from the net, at the end of the procedure i get this error message:
Cannot create file c:\Programs\antmoviecatalog\logs\nameofthefilm.html
i think this happens because mi HD is named G:\, not C:\, what can i do?
That's quite strange... nowhere in the program I use a log folder neither I use a html file. And the path is not hard-coded too since on my PC it is in m:\programs\delphi\moviecatalog\dev\, and on default PC it is c:\program files\ant movie catalog\
Which script do you use ?
