Optional HTML View in Main Window
KaraGarga
Post by KaraGarga »
Hi antp,
Would you consider to add HTML view in Main Window. There can be two optional view: Normal View (standart AMC view) and HTML view (put information into the pre-defined HTML filed)
By this way it is possible to everyone create own user interface I think.
Two example:
1. Collectorz HTML view
2. XMM HTML view
Yes, I plan to add it. The only problem is that I do not know when I will add it :D
I know it would be a quite nice feature, but there are so many nice features that I want to add...
KaraGarga
Post by KaraGarga »
Thanks for the answer :)
I hope you'll found time and energy for development of AMC...
I think it is nice feature to worth add AMC.
