How do I remove the numbers in the list?
Sargan
Post by Sargan »
like the subject says, how do i remove the numbers that is before the name (in the list to the left), It says: Nr | Title
For the moment it is not possible.
okay, thanks for the info
although another question rises: will it be possible?
Probably yes, but I do not know when I will add that ;)
