Import from SQL?
*Guest* - Frau Holle
Import from SQL?
Post by *Guest* - Frau Holle »
I'm using AMC since two years. I make a backup additionally to the normal backup. I don't know how, but all 4 db are corrupt. I've reinstalled AMC, so the problems are really the corrupted AMC-DBs.
The only thing now I have is the SQL-Extract for my template. Do you have a function, which can import sql to the amc? Or, better way: Do you know an editor which can look in the amc-db?
I've tried to open the corrupted AMC-DB with Notepad. He works since 10min :( I'm at a loss what to do.
With notepad you won't be able to do anything.
You can send me the corrupted file by e-mail if it is not too big.
If you send me the SQL extract, I can quickly make a small program to recreate the .amc file from this file.
I really wonder how could your backup become corrupt too... that's very strange.
You can maybe try the 3.5 alpha version : ftp://ftp2.antp.be/antp/temp/amc350.rar
Maybe it is a problem on your PC with the 3.4.3 version, if it was the one you were using.
