SteM
Post
by SteM »
Hi all,
where i can find a reference for the language used for the scripts
Thanks !
ScorEpioN
Post
by ScorEpioN »
this site is nice :
http://delphi.about.com/library/rtl/blrtlmain.htm
and if you use conTEXT (with object pascal syntax) or textPAd (with delphi/pasca syntax) u're OK
to do script look existing scripts
