Suggestion: Change code to match exactly the format of film
vice
Post by vice »
great work!
Problem: i have several films in format MVCD, PSVCD or even RSVCD
the format VCD or SVCD don't match the needs... so pls update your code to match even this formats...
it would be appreciated...
once again ... great work...
for several inputs to improve your prg send me an email: syriust (at) gmx.net
thx
You can edit the values of these lists in Tools -> Preferences -> Drop down lists
vice
format of movies
Post by vice »
sorry guy...
i'm new to your prg... so i had no time to test all... found it by miself...
thx for help...
great work, dude! keep it on!
vice
format of films
Post by vice »
:) once again
now i have edited the formats.... but by export in HTML it won't show the format? have edited dropdownlists of mediatype ... with MoleVCD but nothing is shown in HTML
my fault? had i missed something?
The basic HTML templates do not use this field I think.
You have to edit it to add the field.
e.g. replace the $$ITEM_VIDEOFORMAT by $$ITEM_MEDIATYPE if you want to display the media type instead of the video format. Or add a new column if you know a little HTML.
