I've been using Ant Movie Catalog for quite a while.
I have no problem to run the script from my server, which goes directly to the internet.
When I try to run the scripts on my laptop that goes to the server's firewall and proxy, I can't get it to work. It is like my firewall blocks Ant Movie scripts. Maybe if you would tell me which protocol (TCP/UDP) and port (number and direction) used by the software and the scripts, I could add a rule on my firewall that would let it through.
I tried to monitor the traffic with a port scanner on the server, but surprisingly, i could not see the activity of ant movie catalog.
THank you for your help.
N.B I tried with and without proxy settings in tools ->preferences->scripting, and with or without proxy identification (login/Passwd)[/b]
[Eng] problem with firewall and maybe proxy
