Any php+mysql Templates?
*Guest* - Frau Holle
Post by *Guest* - Frau Holle »
Hi, I'm searching for mysql-templates, because the xml-versions are too slow. But I haven't found any of these templates using the search-function. Have nobody made a mysql template?
bbdoc
Post by bbdoc »
Yes, Free51 did...
viewtopic.php?t=926&start=0
