hi! here is a bug.(ant 3.3.0)
leios
Post by leios »
hi~ I'm Korean user. so my english is so poor. please understand.
there's critical bug when read text including character '&'.
show errormessage and don't get information.
i use ant 3.3.0.
thx for this program.
May i get reference for script?
i wanna use script what coded by myself.
but i don't know basic function for this.
Thx.
Can you give me more information about that ?
Which script did you use ? To retrieve information from where ? For which movie title ?
Script reference is in the help file (Technical information -> Scripting). It uses Object Pascal so common Pascal functions are not detailed.
leios
Post by leios »
i use script what modified from IMDB.ifs by myself.
and retrieve movie description from 'http://films.hitel.net'.
for example there's 'R&B' words in description: ' http://films.hitel.net/film.php?film=B7477'
and 'Access violation at address 005AF288 in module 'moviecatalog.exe', Read of address 00000000.' error is occured.
you want to get this script: 'http://www.leios.net/films.ifs'
thx.
leios
Post by leios »
so using that script(films.ifs), search 'best man' and select xxxxx(The Best Man) - 1999xx xxxx where 'x' is korean.
i wanna next verson has more picture storage:
small poster, big poster, cd label, cd jacket....
I see... "R&B" is a fault in HTML, should be "R&B"... I will try to correct that. Strange that it makes the program crash...
This will probably be corrected within few hours.
There will be multiple images, maybe not in next version, but for sure it will come ;)
I updated the program : now your script seems to work with the movie that you indicated :)
leios
Post by leios »
thx! it works without no error. :)
leios
Post by leios »
leios wrote:thx! it works without error. :)
Great :)
When your script is finished, if you want I can include your script with the program.
