Matroska support
Vlada
Matroska support
Post by Vlada »
first of all, thank You for this great movie catalog. The only thing I really miss now is matroska support. In future versions could be also added support for reading matroska tags.
Btw. What are you currently working on, if you are? If you don't have enough time to work on the Movie Catalog, I understand it. There is never enough time :-( Have you ever thought about adding your project to sourceforge.net? Maybe somebody would join it and would help you with the development.
Vlada
It will be added in version 3.5.
Same for ".ogm" support.
This is the next feature that has to be added before a real public 3.5 version.
karl lillevold
RMFF
Post by karl lillevold »
I just tried Ant Movie Manager today, and I am looking forward to import support for Matroska. It would be great if RMFF import support was added too ;)
http://www.bunkus.org/videotools/librmff/
After Matroska support is added, there is always the option to batch convert everything to MKV and then import though..
