MPAA Ratings required
Dadang
Post by Dadang »
I can say, Ant Movie Catalogue is simple the best movie organizer in the world. It is FREE and it is customize-able. :grinking:
It is very useful before I put movie in the player, I check with the synopsis and comment & review.
I just need ONE more field, it is Movie Rating (like MPAA, www.filmratings.com) .. bcos sometimes I don't know what content on the movie, so before watch them with my kid, better yet to check.
Some movie cover are just too neglect to put Movie Rating in their back cover.
Thus, so far I enter the movie rating manually under field RESOLUTION.
Thank you and keep the good work!!
A field for that will maybe be added in version 4
