Origons export buggy
Atmosfear
Post by Atmosfear »
the origons export in 3.5.0 alpha/D7 is buggy, it exports fields in wrong order so after importing onto origons website eg. title is mapped to movie rating.
Thanks for the info I will check that.
Is it still working with version 3.4.3 ? (to be sure that the problem comes from AMC)
Atmosfear
Post by Atmosfear »
I can't check as my database uses the x.x/10 rating and I don't wanna risc trashing it by opening with an older version. Besides I have only one origons import as non vip user. Btw. looking at the version string in the .ogs file it says AMC 3.4.2...
I forgot to change the version number I guess.
After check, this version number is normal.
The site probably expects it. It is the file format of AMC 3.4.2
The bug was that it exported also fields of 3.5 ("checked" and "formatted title", that have been added for export/printing)
I corrected the bug, the number of columns seems correct now.
I put the new file at the same location :
ftp://ftp2.antp.be/antp/temp/amc350.rar
Atmosfear
Post by Atmosfear »
thx, I'll check if it works once I find some time to bug origons support to reenable my import try :)
