Delphi 6 Source Code
George Robinson
Post by George Robinson »
What version specific features do you use for Ant Renamer that will prevent it from compiling on Delphi 6 ?
Do you think it has a chance of compiling under Delphi 6 ?
George
I do not think there are specific things.
You only need one more component, Theme Manager. It is needed to be able to use VirtualTreeview under Delphi 6 (you get it from same site as VirtualTreeview), but all other components should work fine.
The program may not look very good under themed Windows XP.
