add A-Z option
n7of9
add A-Z option
Post by n7of9 »
i have used Willspo's plain template (slightly modified) to export to html...i am very pleased with the result as i only want something simple
http://members.optusnet.com.au/n7of9web/
what i would like to add, just under the cetegories, is an A-Z which would work in the same way as when you press a category...i have seen other templates that have this but i cannot figure out which part of the java script i need to add
can anyone help me out?
