click image to play mpg movie from file
antfan
Post by antfan »
could I make a suggestion on a future improvement. Is it possible to have a link made from a movie graphic that would start a .mpg movie file on the hardrive?
It will be probably integrated better in a future version, but in current version you can put the path & name of a file in the URL field : it will be opened correctly when you click on the button on the right of the field.
antfan
Post by antfan »
That works great for me and saved me hours of creating it in other programs. Thank you! Thank you!
