Help renaming folders
wvanlue
Post by wvanlue »
I am able to rename files all day long, but I need to be able to rename folders.
Does anyone have any instructions on how to do this?
Re: Help renaming folders
There is a "add folders" button, or you can drag & drop them from Windows Explorer (holding down the Ctrl key, in case you checked the option "do not ask again" when it asks what you want to add when doing a drag & drop).
Otherwise you can also check the Help included with the program ;)
wvanlue
Post by wvanlue »
The Add Folders allows you to add an entire folder to Ant Renamer, but it still only renames the files, not the folder.
Is there any help on how to change the folder names?
When using "Add folders', there is an option to add the folders themselves. Then they will appear in the list among the files (or just folders if you uncheck the option to include files) and you can rename them.
