Print preview
RalphMalph
Print preview
Post by RalphMalph »
I have this program since yesterday and i think i like it.'
Till now i have 1 comment:
To see a print preview of complete movie list you have to select all movies before going to the pint preview.
Isnt it easy to put a button in the print preview screen with "select all"
Keep on the good work.
you can also select none, and all will be used. Just click again on the selected movie to unselect it, then call the print window.
In next version I think I will add a switch "print all"/"print selected" in the print window.
RalphMalph
hmmm, ok...that is possibility...what you see nowadays a checkbox for "select all" , thats why i mentioned it.
Thanks for fast reply
