adding new movie using "get information from script&quo
nikolaj
Post by nikolaj »
I use this option and then i connect to IMDB (US) import with small picture. Normally it works fine for me, but i happens a few times that the
when i export it to a html file that the field "description" is not complete
For instance if you look under 's' and see the movie 'Spartan" you will
notice that at 'description' the only word is you can see is the "A" :??: nothing
else. If you look at "d" and see Daredevil, you will see that the last
line in not complete :??:
I get all information correct from imdb. I have tried to change it
manually, but it remains the same.
Any help will be much appreciated
I use
Template #2 - Created By Twink - TwinkMan666@hotmail.com      -->
<!-- Made for Ant Movie Cataglog http://www.buypin.com/moviecatalog.php  -->
<!-- Based on my old template with lots of ideas from Willspo's Template -->
<!-- Keep up the good work guys!!!                                       -->
<!-- LastUpdated: 17/10/02  Version BETA 0.5
I have upped my catalogue ( btw it's a small one) at:
http://www.nikolaj.demon.nl/movielist/movielist.html
and here is the html.file. Maybe someone can see what i have done wrong
<!-- Movie Template #2 - Created By Twink - TwinkMan666@hotmail.com      -->
<!-- LastUpdated: 17/10/02  Version BETA 0.5                             -->
<!-- Start of Variables -->
<script>
/* User Variables (CHANGABLE)*/
var category = "(All)";                    //Category to Show First
var MaxPerPage = 4;                       //Movies Per Page
</script>
<!-- End of Variables -->
<!-- Start of HTML -->
<html>
<head>
<title>$$OWNER_NAME Nikolaj's movie list</title>
  <style TYPE="text/css">
    text,body,p,div,span,th,td,ul,li { FONT-SIZE: 9pt; FONT-FAMILY: Trebuchet MS, Verdana, Arial, Helvetica, sans-serif; color: #edf0f8; background: #5D6C85; }
    HR { color: black; }
    img { border: 0px; }
    A:link { COLOR: black; background: #9BAECD; }
    A:visited { COLOR: #5D6C85; background: #9baecd; }
    A:hover { COLOR: #9BAECD; background: #edf0f8; }
    A:active { COLOR: #9BAECD; background: #edf0f8; }
    td.blk { color: black; background: #9BAECD; border: solid; border-color: #5D6C85; }
    table.blk { color: #9BAECD; background: #8b9dbd; border: solid; border-color: #8b9dbd; border-width: thin; }
    table.lgt { color: black; background: #d1d1e1; border: solid; border-width: 1; border-color: #edf0f8; }
    td.lgt { color: #white; background: #5D6C85; border: solid; border-width: 1; border-color: #d1d1e1; }
    p.title { font-size: 16pt; font-weight: bold; }
  </style>
</head>
<body onLoad="init()">
  <p>
    $$OWNER_NAME Nikolaj's movie list<br>
    Last updated on $$DATE<BR>
    Total: $$TOTALMOVIES movies<br>
    <a style="color: #edf0f8; background-color: #5D6C85" href="javascript:dToggle(oOptions,-1)">
      Options
    </a>&nbsp
    <a style="color: #edf0f8; background-color: #5D6C85" href="javascript:dToggle(oFind,-1)">
      Search
    </a>
</p>
<script>
  <!-- Waiting Picture/Message In here
    document.write("<table id = 'wait' class='blk' border='1' cellspacing='0' cellpadding='5'>");
    document.write("<tr><td id='wait_text'>Please wait while list loads...</td></tr>");
    document.write("</table>");
</script>
<table ID='oOptions' class= "blk" border='20' cellspacing='0' cellpadding='5' style='display:none'>
<thead>
   <tr>
    <td class="blk" nowrap colspan="2"><b>Options</b></td>
   </tr>
</thead>
<tbody>
   <tr>
       <td class="lgt" nowrap>Items Per Page</td>
       <td class="lgt" nowrap><input type="text" name = "perpage" onChange="MaxPerPage = round(perpage.value,3);showCategory();">
</td>
   </tr>
   <tr>
       <td class="lgt" nowrap>Group By</td>
       <td ID = 'oOptionsCategories' class="lgt" nowrap>
       </td>
   </tr>
</tbody>
</table>
<table ID = 'oFind' class = "blk" border='20' cellspacing='0' cellpadding='5' style='display:none'>
<thead>
  <tr>
    <td class="blk" nowrap colspan="2"><b>Search</b></td>
    </td>
  </tr>
</thead>
<tbody>
    <input type="text" name = "oFindText">
    <input type="submit" value = "Search" onclick = "javascript:search(oFindText.value);">
  </td>
</tbody>
</table>
<br>
<table ID='oMovieTable' class= "blk" border='20' cellspacing='0' cellpadding='5' style='display:none'>
<thead>
  <tr>
    <td class="blk" nowrap>&nbsp</td>
    <td class="blk" nowrap style="cursor:hand" onclick ="sortby('OriginalTitle')">Title</td>
    <td class="blk" nowrap style="cursor:hand" onclick ="sortby('Category')">Genre</td>
    <td class="blk" nowrap style="cursor:hand" onclick ="sortby('Year')">Year</td>
    <td class="blk" nowrap style="cursor:hand" onclick ="sortby('Length')">Length</td>
    <td class="blk" nowrap style="cursor:hand" onclick ="sortby('Source')">Source</td>
    <td class="blk" nowrap style="cursor:hand" onclick ="sortby('VideoFormat')">Format</td>
    <td class="blk" nowrap style="cursor:hand" onclick ="sortby('Languages')">Languages</td>
    <td class="blk" nowrap style="cursor:hand" onclick ="sortby('Subtitles')">Subtitles</td>
  </tr>
  <tr>
    <td ID='oGroupSel' class = "blk">
    <td ID='oGroupName' colSpan='8' class = "blk">
    </td>
  </tr>
</thead>
  <tbody ID='oMovieList' class = "lgt">
  </tbody>
  <tbody ID='oPages'>
     <td ID = 'oPagesBack' class = 'blk'>
     </td>
     <td ID = 'oPagesMid' class = 'blk' colspan = "7">
     </td>
     <td ID = 'oPagesNext'class = 'blk'>
     </td>
  </tbody>
</table>
<p>Created with <a style="color: #edf0f8; background-color: #5D6C85" href="http://www.buypin.com/moviecatalog.php" target="_blank">Ant Movie Catalog</a>.</p>
</body>
</html>
<!-- End of HTML -->
<!-- Start of Script -->
<script>
//SYSTEM VARIABLES
var StartFrom = 0;        // Start Showing From (used for pages)
var movies = null;        // Holds All Movies
var movie = null;         // Current movie
var index = 0;            // Current movie number in this category
var sortedby = 0;         // Last Column Sorted By
var sortasc = true;       // Sort Ascending/Decending
var ShownCategory = new Array();  //Array of Category Types
perpage.value = MaxPerPage;
//GENERAL FUNCTIONS
String.prototype.trim = function(){
   return this.replace(/(^\s*)|(\s*$)/g, "");
function round(number,X) {
   return Math.round(number*Math.pow(10,X))/Math.pow(10,X);
function dToggle(x,y){
   if (y==-1&&x.style.display==""||y==0)
     x.style.display="none";
   else x.style.display="";
//DISPLAY FUNCTIONS
//Add Type of Category (Letters, Genre, Format)
function AddCategoryType(Name,Variable){
    var o = ShownCategory.length;
    ShownCategory[o] = new ShownCategoryType(Name,Variable);
    if(o==0) ShownCategory[o].shown=true; //Default to Showing First Category.
    oOptionsCategories.innerHTML +=  "<input type = 'checkbox' "+(ShownCategory[o].shown==true?"checked":"")+" onclick='ShownCategory["+o+"].shown=!ShownCategory["+o+"].shown;init();'>"+Name+"<br>";
//Create Actual Category (A-Z, Action/Comedy, Divx/MPEG)
var ShownCategories = new Array();
function clearCategories(){
function createCategory(X){
  ShownCategories[ShownCategories.length]=X;
function showCategories(){
   oGroupName.innerHTML = "";
   ShownCategories.sort(sort2);
   for(var i=0;i<ShownCategories.length;i++){
     oGroupName.innerHTML += "<a href='javascript:StartFrom=0;category=\""+ShownCategories[i]+"\";showCategory();'>"+ShownCategories[i]+"</a>&nbsp";
   oGroupName.align = "center";
   oGroupName.style.fontWeight = "normal";
//Wipe All Movies From Display (called when swapping Category/Page)
function clearMovies(){
   oMovieList.innerText ="";
//Toggles Extra Movie Details
function showDetails(){
   dToggle(eval(window.event.srcElement.toggle),-1);
//Reads Movies into Array Sorting into Categories
function init() {
   movies  = new Array();
   var catArray = null;
   var cArray = null;
   var temp;
   var Category = "";
   clearCategories();
    var elements = document.body.getElementsByTagName("Movie");
//  var xmldoc=new ActiveXObject("MSXML2.DOMDocument.3.0");
//  xmldoc.load("movies.xml");
//  elements = xmldoc.getElementsByTagName("Movie");
   movies["(All)"] = new Array();
   createCategory("(All)");
   for (var i = 0; i < elements.length; i++) {
     temp = "";
     for(var x =0;x<ShownCategory.length;x++){
       var value = eval("elements[i]."+ShownCategory[x].Variable);
       if(ShownCategory[x].shown==true)temp += " / " + (value!=""?value:"(None)");
     cArray = new String(temp).split(" / ");
     for (var j = 0; j < cArray.length;j++){
       Category = cArray[j].trim();
       if (Category != null && Category != "" && Category != "undefined") {
         catArray = movies[Category];
         if (catArray == null) {
           catArray = new Array();
           movies[Category] = catArray;
           catArray[0] = elements[i];
           createCategory(Category);
         } else {
           catArray[catArray.length] = elements[i];
    movies["(All)"][movies["(All)"].length] = elements[i];
   showCategories();
   showCategory();
//Loop Through Movie[category] and Show each movie
function showCategory(){
   if(movies[category]==null) category = "(All)";
   oGroupSel.innerHTML = "<CENTER>"+category+"<CENTER>";
   clearMovies();
   EndAt=((movies[category].length-StartFrom)<MaxPerPage?(movies[category].length):MaxPerPage+StartFrom);
   if(movies[category].length==0||StartFrom==EndAt){
      oRow = oMovieList.insertRow();
      oCell = oRow.insertCell();
      oCell.align = "center";
      oCell.className = "lgt";
      oCell.innerHTML = "No Movies to Display<br>";
      oCell.colSpan="7";
   } else {
     for(var i = StartFrom; i<EndAt;i++){
       if(i!=StartFrom){
         oCell=oRow.insertCell();
         oCell.colSpan="7";
         oCell.className = "blk";
       showMovie(i);
   if(movies[category].length>MaxPerPage){
     oPagesBack.innerHTML = "<CENTER><a href='javascript:StartFrom="+(StartFrom-MaxPerPage>0?StartFrom-MaxPerPage:0)+";showCategory();'>Back</a></CENTER>";
     oPagesMid.innerHTML = "<CENTER>Page: " + round((StartFrom/MaxPerPage)+1,0) + " of " + round((movies[category].length/MaxPerPage)+1,0) + "</CENTER>";
     oPagesNext.innerHTML = "<CENTER><a href='javascript:StartFrom="+(StartFrom+MaxPerPage<movies[category].length?StartFrom+MaxPerPage:StartFrom)+";showCategory();'>Next</a></CENTER";
   }else{
     oPagesBack.innerHTML = "";
     oPagesMid.innerHTML = "";
     oPagesNext.innerHTML = "";
   dToggle(oMovieTable,1);
   dToggle(wait,0);
function showMovie(i){
  movie = movies[category][i];
  var oRow;
  var oCell;
  var temp;
  temp="<center>";
if(movie.URL!="")temp+="<a href = '"+movie.URL+"' target='_blank'> ";
  if(movie.PICTURE!=""){
    temp+="<img src='"+movie.Picture+"' width='75' height='110'>";
  }else{
    temp+="<img src='nopic.gif' width='75' height='110'>";
if(movie.URL!="")temp+="</a>";
  temp+="<br><img src='appr"+round(movie.Rating/10*4,0)+".gif' >";
  temp+="</center>";
  var layout = new Array()
  layout[0] = new Array();
  layout[0][0] = new Field("123");
  layout[0][0].HTML = temp;
  layout[0][0].rowSpan = "2";
  layout[0][0].action = false;
  layout[0][1] = new Field("movie.OriginalTitle");
  layout[0][1].fontWeight = "normal";
  layout[0][2] = new Field("movie.Category");
  layout[0][3] = new Field("movie.Year");
  layout[0][4] = new Field("movie.Length");
  layout[0][5] = new Field("movie.Source");
  layout[0][6] = new Field("movie.VideoFormat");
  layout[0][7] = new Field("movie.Languages");
  layout[0][8] = new Field("movie.Subtitles");
  layout[1] = new Array();
  layout[1][0] = new Field("movie.Description")
  layout[1][0].action = false;
  layout[1][0].colSpan = "8"
  for(y=0;y<layout.length;y++){
   if(layout[y] == null)break;
    for(x=0;x<layout[0].length;x++) {
       if(layout[y][x] == null)break;
      (oCell = oRow.insertCell());
      oCell.innerHTML = eval(layout[y][x].field)+ "&nbsp";
      if(layout[y][x].HTML!="")oCell.innerHTML = layout[y][x].HTML;
      if(layout[y][x].action==true){
        oCell.style.cursor = "hand";
        oCell.onclick = showDetails;
        oCell.toggle =  "Expand" + movie.Number;
      oCell.rowSpan = layout[y][x].rowSpan;
      oCell.colSpan = layout[y][x].colSpan;
      oCell.style.fontWeight = layout[y][x].fontWeight;
  oRow.id= "Expand" + movie.Number;
  oCell.vAlign = "top";
  oCell.innerHTML = "<strong>Year:<br>Director:<br>Actors:</strong>"
  oCell.innerHTML = movie.Year + "&nbsp<br>" + movie.Director + "&nbsp<br>" + movie.Actors;
  oCell.colSpan="8";
  oRow.style.display = "none";
//STRUCTS
function Field(FieldName){
   this.field = FieldName;
   this.rowSpan = "1";
   this.colSpan = "1";
   this.fontWeight = "";
   this.HTML = "";
   this.action = true;
function ShownCategoryType(Name,Variable){
   this.Name = Name;
   this.Variable = Variable;
   this.shown = false;
//SORT FUNCTIONS
function sortby(X){
   if(sortedby!=X||sortedby==X&&sortasc==false){
     sortedby = X;
     movies[category] = movies[category].sort(sort);
     sortasc=true;
   } else {
     movies[category] = movies[category].sort(revsort);
     sortasc=false;
   showCategory();
function sort2(X,Y){
   if(X<Y)return -1;
   if(X>Y)return 1;
   return 0;
function sort(X,Y){
   if (eval("X."+sortedby)<eval("Y."+sortedby)) return -1;
   if (eval("X."+sortedby)>eval("Y."+sortedby)) return 1;
   return 0;
function revsort(X,Y){
   if (eval("X."+sortedby)>eval("Y."+sortedby)) return -1;
   if (eval("X."+sortedby)<eval("Y."+sortedby)) return 1;
   return 0;
//FIND
function search(X){
   if(movies["(Search)"]==null) createCategory("(Search)");
   movies["(Search)"] = new Array();
   var v_regexp = new RegExp(X,"gi");
   for(var i = 0;i<movies["(All)"].length;i++){
   if(v_regexp.test(movies["(All)"][i].OriginalTitle)||v_regexp.test(movies["(All)"][i].Description))
       movies["(Search)"][movies["(Search)"].length] = movies["(All)"][i];
   showCategories();
   category="(Search)";
   StartFrom = 0;
   showCategory();
</script>
<!-- End of Scripts -->
<!-- Start of Movies -->
</Movies>
  $$ITEM_BEGIN
  <Movie
    Number = "$$ITEM_NUMBER"
    Source = "$$ITEM_SOURCE"
    Rating = "$$ITEM_RATING"
    OriginalTitle = "$$ITEM_FORMATTEDTITLE1"
    Director = "$$ITEM_DIRECTOR"
    Country = "$$ITEM_COUNTRY"
    Category = "$$ITEM_CATEGORY"
    Year = "$$ITEM_YEAR"
    Length = "$$ITEM_LENGTH"
    Actors = "$$ITEM_ACTORS"
    URL = "$$ITEM_URL"
    Description = "$$ITEM_DESCRIPTION"
    Comments = "$$ITEM_COMMENTS"
    VideoFormat = "$$ITEM_VIDEOFORMAT"
    Languages = "$$ITEM_LANGUAGES"
    Disks = "$$ITEM_DISKS"
    Picture = "$$ITEM_PICTUREFILENAME"
    Subtitles = "$$ITEM_SUBTITLES"
  $$ITEM_END
</Movies>
<!-- End of Movies -->
<script>
//CATEGORIES
AddCategoryType("Letters","getAttribute('OriginalTitle').charAt(0)");
AddCategoryType("Category","getAttribute('Category')");
AddCategoryType("Source","getAttribute('Source')");
AddCategoryType("Format","getAttribute('VideoFormat')");
AddCategoryType("Subtitles","getAttribute('Subtitles')");
// AddCategoryType("Number","getAttribute('Number')");
AddCategoryType("Director","getAttribute('Director').charAt(0)");
</script>
Both error are caused by the presence of the " character in the description field.
Try to replace them by '' (two ' characters)
You can to that easily by script using :
program NewScript;
  s: string;
  s := GetField(fieldDescription);
  s := StringReplace(s, '"', '''');
  SetField(fieldDescription, s);
YEP, it works :grinking:
thanks for you help !!!
