Comparing two lists
FRay
Comparing two lists
Post by FRay »
PLS, realise function: comparing two lists by choosing fields
What do you mean by "compare" ?
rickympl
Post by rickympl »
Hello, I was probably thinking of the same thing.
Compare two lists, and then give you a window where it shows the differences between the lists. One side showing the movies I don't have that "friend" has and right side showing movies "friend" has and I don't.
At least that what i think the other user meant by compare.
I think it would be a good addition to the prog.
Thankz.
yes, it could be useful in some cases. I'll keep it as idea for later.
