exprting & image sizes..
shawn
Post by shawn »
when exporting to html.. is there any way to resize cover images to smaler? that force picture size by adding atributes aint good if i have huge cover scans..
Currently it is not possible.
It will probably be added in the future, but until then you have to use an external soft for that (like XnView or Ifranview, I think they can do that).
shawn
Post by shawn »
ok.. thx for fast reply
