export to html isnt in alphabetical order anymore...
fum
Post by fum »
I recently upgraded from version 3.3.0 and now when I export from the same template its ordered by #number. In version 3.3.0 I could right click and select group by media label and it would export from a-z. Any help would be appreciated. Thanks.
the group by thing does not modify the sort order of the export
For that you have to use the "sort by" list at the bottom of the Export window.
fum
thanks
Post by fum »
:grinking:
