The version 2.08 is not completely finished yet, but if you want you can already try a "beta" version of it.
It includes an help file for the first time, so even people that are new to the program may want to see it.
But I do not recommend to test it if you are not comfortable with expanding zip files for manual install, or if you can't/won't use the program in English.
A version with automatic installer will be released officially when the program will be considered as "stable" and when the translation files will be updated.
More information and the program itself can be found there :
viewtopic.php?t=1435
Version 2.08
The version is finally released.
It should have been done one month ago, but I was quite lazy for finishing french translation of the help file
What's new in 2.08:
* Help file (English & French only for the moment)
* Added support for some command-line parameters, see help file.
* More advanced formatting system for some actions, especially for mp3.
* Option for using Creation date instead of Modification date, in Date & time action.
* Option for reverting to start value when changing folder, in Enumeration action.
* Option for storing log to a file, with or without append.
* Possibility to filter log entries (successes, errors, not renamed files).
* Few bugs corrected
As usual, it can be downloaded from http://www.antp.be/software/renamer/download
What's new in 2.08:
