Template Avery/Zweckform Labels/Etiketten/Etiquettes 4737
p_ter
Post by p_ter »
Hi there,
i made a template for Labels from Avery/Zweckform which are pretty common here in germany. i have all my movies in some of those 100 cd folders and i wanted some kind of labelling and i had those labels (4737) around
i used a different font for my labeling (myriad pro light condensed) but since that is no open font i changed the template to arial. it was a neat peace of work because you cannot adjust really precice but it worked somehow.
so if you are looking for a template for those labels you just found it.
zweckform_4737.frf
greetings,
peter
