There is not for the moment.
I planned to do that, but a stand-alone program that uses the catalog file would be better, so it could be kept as resident program and would use less memory than AMC.
Or I could make a CGI version, to use with Apache for example.
I think that mysql stortage, plus php templates would turn AMC in the most simple, light and complete Media Cataloger around ...
Only one storage, mysql, shared between the amc executable and the php template.
There are a plenty of web server supporting php around...
